4 members (farmallb, Gib70, Gdads51, Nick in Manitou), 132 guests, and 3 robots.
Topics128,088
Posts1,055,998
Members48,430
#1581901 07/06/2025 5:45 PM
2 Offline
A couple years ago i bought all new brake hoses for my coe off ebay. I was putting the truck away for the winter and the brakes where sticking on the back axle. So i just got to check it out. I was looking at the brake hose and wondering if it could be swelled shut. I noticed that the hose was like a wet noodle and and it looked like it was sweating. It had a bunch of little dots like the brake fluid was weeping through the hose. I looked at the front and 1 of those was the same. I changed them all. The hoses said made in argentina also said dot. Probably some inferior hose. Im just glad they didn’t blow out . Any how I replaced the hoses and the brakes don’t seem to be sticking now. Hopefully that was the problem time will tell
29tons #1581909 07/06/2025 7:10 PM
Wow, That's scary. Glad you got it figured out before you took it out on the road.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
29tons #1583082 07/20/2025 2:50 PM
Had the same issue with my rear brakes not releasing, replaced the wheel cyl. on one side only to find out the rear hose was plugged
