1 members (Peggy M), 321 guests, and 4 robots.
Topics128,169
Posts1,057,102
Members48,463
It seems that I am constantly running into holes that don't quite line up, and need to be elongated. I've used rat tail files, shaft mounted stones, and drill bits to get this done. I suppose that the file is the only one of these methods that's actually correct. Stones get eaten up real fast, and drill bits were never designed for that. So, I've wondered about trying to use an end mill mounted in a hand drill. I've tried rasps in a drill, but they aren't real easy to use. So, I'm hoping that you guys can educate me on the best tool for this purpose.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
One of my techs needed to elongate some holes today. The quickest, most accurate way he found was to use a Milwaukee mini belt sander, then finish up with a rotary file in a die grinder.
What Mark said. If you don't have a die grinder, a drill motor works OK, but the higher speed of a die grinder is better.
I have a set similar to THIS.
I do have a die grinder. I'll pickup a set of those rotary bits like the ones in your link. One big advantage to doing everything yourself is that it gives you an honestly legitimate, and justifiable reason to buy more tools. THANKS
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1947 Indian Chief
1943 Indian 741
H Online: Content
I use an electric die grinder, and a speed controller to tailor the speed of the carbide burr to the job. After I wore out several air die grinders and a compressor or two porting and polishing race engine cylinder heads, I decided that a 1/4" shank carbide burr in an electric grinder was the way to go. Sandpaper "cartridge rolls" to do the final shaping.
www.ebay.com/itm/256894944599?
www.ebay.com/itm/316673589763?
Moderated by  MNSmith
