Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
6 members (Steelonsteel, EchoBravoSierra, Grandpas_48, Ridgeback, klhansen, TooMany2count), 596 guests, and 1 robot.
Topics126,780
Posts1,039,291
Members48,100
Most Online2,175
Jul 21st, 2025
Moderated
Moderated
Have a cracked block on a perfectly running 52 216
Found a 235 think from a 57
Want to use the 235 but need info about the water pump length and position
Any information would be greatly appreciated
Where is the crack? If it's in the water jacket down low on the driver side, every 216 ever made has that. It can be EASILY patched with epoxy.
Since it's a zero pressure system, it isn't any big deal.
1950 Chevrolet 3100 (Ol' Roy)
1939 Packard Standard Eight Coupe (The Phantom) | 1956 Cadillac Coupe de Ville (The Bismarck) | 1956 Cadillac Sixty Special Fleetwood (The Godfather) | 1966 Oldsmobile Toronado (The Purple Knif) | 1966 Ford Mustang (Little Red) | 1964 Ford Galaxie 500 coupe | 1979 Ford F-100 | 1976 Ford F-150 (Big Red) | 1995 Ford F-150 (Newt)
BroB,
I ran my cracked leaking 216 for almost a year. Zero pressure so it was a slow leak. I then put a 1957 235 in. I used the "Adapter" plate..for 216 water pump.
Todd
Last edited by Phak1; 06/28/2025 9:27 PM. Reason: Removed text requesting poster to start a new thread.
1950 Chevy 3100
AD Addict & Tinkerer
I moved your thread so you will get the attention it deserves. Posting a question in another thread (aka, piggybacking) is frowned upon in forums. It confuses the readers as we don’t know what question is being addressed. it’s always better to start a new thread.
While I have your ear, Welcome to the ‘bolt! Spend a little time and introduce yourself in the “Welcome Center” forum. Tell us a bit about yourself and your truck.
And of course we bolters love pictures so include a few. Here’s a link to instructions on how to add pictures to a post.
Let me give you this helpful guide to help you navigate thru the different forums on Stovebolt.
Phil
Project Journals
Stovebolt Gallery Forum
i had a 235 that was cracked down the side we put a blanket over the radiator and got it good and hot then poured a bottle of Bars Leak in it. it never leaked a drop for 5 years that i had it.
Jay D.
Back to the original question- - - -the late model 235 from mid-year 55 to 63 has a water pump that is recessed into the front of the engine block. The shaft is too long to work with the 1952 radiator, and the fan will sit too low on the radiator for good cooling. The simplest fix is to use the adapter plate that Stovebolt forum member "Pre-68 Dave" makes and sells. It allows the 216 style high mount water pump to be used with the late model 235 engine. Another option is to use a hydraulic press to push the fan hub back about an inch on the late model pump and shorten the shaft by the same amount. That does not solve the fan position problem. You will also need to use a 216 harmonic balancer to keep the water pump and fan speed correct when using the 216 type pump. Please don't scrap the 216 engine- - - -I'd be interested in it, with or without the crack.
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.035s Queries: 14 (0.032s) Memory: 0.6156 MB (Peak: 0.6827 MB) Data Comp: Zlib Server Time: 2025-09-22 19:42:06 UTC
Valid HTML 5 and Valid CSS
