6 members (Lostbuthaulinass, klhansen, Otto Skorzeny, Charles in CA, Peggy M, Gray_Ghost), 114 guests, and 2 robots.
Topics128,059
Posts1,055,825
I am assembling my bed for my 1953 half ton. I am reusing the sides and front. The angle strips that weld to the inside of the bed sides were rusted away, so I had to remove them and buy new ones. I have the 2 outside bed boards laying in the bed against the sides. The new angle strips that extend out over the outer boards are not exactly the same length as the boards. They are slightly shorter. So, I need a little help in order to figure out exactly where to position the strips. At the rear of the bed, should the metal strips stop right at the end of the wood, or should the extend past the wood to the rear sill, or should they be a little shy of the end of the wood. I don't have a correct truck here to look at, so if one of you guys have one you think is correct, please take a look and let me know please. THANKS
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
I took one of the old trashed angle strips and positioned it using the bolt holes that the fender bolts go through. In the bed front, the angle strip stopped at the bolt flange on the front panel. On the rear, it extended beyond the wood slightly. So, I'm assuming that this is normal and correct. Could one of you please confirm this for me please. THANKS
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1947 Indian Chief
1943 Indian 741
Mike, the angle strips on mine (new ones from Mar-K) extend nearly to the back of the rear cross sill.
As far as the front, I believe the originals stopped short of the bed front panel flange, as it goes on the inside to allow assembly with the angle strips welded to the bedsides.
Here's some pics of the original bed and the rebuilt one.
Moving your thread over to Making a Stovebolt Bed.
Bed rear corner
Bed front corner
Thanks Kevin, that confirms my thinking. I can move forward a little further now. The black on your wood and bed strips looks nice. What did you use, and how did you apply it?
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1947 Indian Chief
1943 Indian 741
I can confirm that the bed angle strips overlap the rear sill.
In my case I bolted my strips in place rather than welding to provide a little wiggle room for assembly. There are 2 bolts that are visible with everything assembles between the front 2 stake pockets. I used acron nuts on those to give it a finished appearance.
1949/50 3600 Project
Follow in Project Journals
O Online: Content
Paint the acorns blue.
1950 Chevrolet 3100 (Ol' Roy)
Originally Posted by Mike Burns
... The black on your wood and bed strips looks nice. What did you use, and how did you apply it?
Thanks Mike, here is the info you were asking about. Look a couple posts down from that one also, for pics of the can of stain I used.
