4 members (BC59, Gdads51, carbking, papas52), 89 guests, and 3 robots.
Topics128,181
Posts1,057,180
Members48,465
It looks like a 2-piece neoprene seal for a big block Chevy V8 can be adapted to the GMC sixes- - - -228 through 302. It will require machining of the block and rear main cap, somewhat similar to the way a Chevy six is done, and fabrication of a seal holder from either steel or aluminum. Then make a small change in the seal surface diameter on the crankshaft. This looks like a fairly straightforward operation for any engine machinist with a few brain cells to rub together!
On the 302, there isn’t enough meat. Especially in the case reinforcement ribs. I hope you can figure out a way to accomplish that.
That actually looks like it's going to be simpler than the conversion of a Chevy block for the full circle lip seal. More info as I develop a prototype!
I’m looking forward to your design. Good luck.
Currently, I've got four GMC engines- - - -a 228, a couple of 248s, and a 270. Two more 270s are on the way soon. If my idea works as I hope it will, I'll be making several of the adapters.
