7 members (MickeyP, RoadsScholar, Gdads51, 1955 1 Series, thekid1950, tclederman, klhansen),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,068 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 29 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 29 | Hey gang,
Just did some routine clean up on my 53. Plugs, cap, rotor, wires, new gaskets on the oil pan, pushrod cover, and valve cover, hoses, and fluids. Interestingly, the trans was leaking too from the fill plug so I changed that fluid with only a half cup of fluid coming out, so really, it wasn’t a fluid change more of an addition!
So with the ignition, I was reading about the octane gauge (if you call it that) on the distributor base. Mine is set to 0. The truck runs great, but there is a noticeable cough when giving the gas, so I figured a little ignition advance was in order. Would this adjustment give me a few degrees advance that I desire? Pretty neat that there’s a little gauge there.
Cheers Dave | | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | Unless your timing is way off, slight timing variance won't generally cause a "cough". If a timing light indicates that the ball is on the needle and your octane selector is set at zero, you should have 5 degrees advance which is called for on a 216. What carburetor do you have and how would you describe its current condition? Recently rebuilt, properly adjusted? You didn't mention anything about your points. Dirty points make for a weak spark. Will that cause a cough? Maybe. It's something which requires checking and maintaining regardless. Bottom line is, I wouldn't start with adjusting the timing away from factory setting of 5 degrees BTC in an attempt to chase down a cough.
| | | | | Joined: Jul 2014 Posts: 29 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 29 | Thanks, Carl. Points are new and adjusted. Carb is probably in need of a rebuild and may be the source of the stumble. It’s well used, but seems to run well. Haven’t checked the accel pump yet. I’ll dive more into it tomorrow.
Edit; I see you added more info. Agreed, and I’ll check that tomorrow too (ball and pointer). Was just throwing out some questions this evening. I do disagree that bad timing will cause a stumble. Fixed that in many a car.
| | | | | Joined: Dec 2024 Posts: 114 'Bolter | | 'Bolter Joined: Dec 2024 Posts: 114 | Does it cough as soon as you give it gas? If so, might be accelerator pump. A cough is usually fuel related, but can be caused by a sticky advance. Check advance weight springs and pivots, and check for vacuum advance leaks; especially if the cough occurs a bit after giving it gas.
Geoff
1955 2nd Series 3600 235 cid, 4 sp. - Current 1979 Chevy K10 350 cid 4 sp -Sold 1955 2nd Series Wide Window 283 cid 3 sp - Totaled
| | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | Thanks, Carl. Points are new and adjusted. Carb is probably in need of a rebuild and may be the source of the stumble. It’s well used, but seems to run well. Haven’t checked the accel pump yet. I’ll dive more into it tomorrow.
Edit; I see you added more info. Agreed, and I’ll check that tomorrow too (ball and pointer). Was just throwing out some questions this evening. I do disagree that bad timing will cause a stumble. Fixed that in many a car. Yes, incorrect timing can cause a "stumble". You originally indicated that you had a "cough". So now I do not know what you have. In any case, it is much easier to double check the timing than it is to rebuild a carburetor. It may well be that your carburetor needs some attention, but it is always best to check everything else before you move on to the carburetor.
