Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
11 members (52Carl, Otto Skorzeny, Fifty-Five First, Danielbolt, Peggy M, Bill Hanlon, Waveski, Lightholder's Dad, hapydirty, Guitplayer, cspecken), 530 guests, and 1 robot.
Topics126,781
Posts1,039,301
Members48,100
Most Online2,175
Jul 21st, 2025
I have a 1952 3100 1/2 ton pickup and am planning on installing an Oakie bushing to prevent overfilling the differential with oil from the tranny. While I am at it I also plan to replace the U-joint.
Question:
I understand that I need to remove the transmission “mount” which connects up to the flange via four bolts to the tranny, but do I also need to remove the transmission “crossmember” in order to have enough access to remove/install Oakie bushing and replace u-Joint? I am doing this all without a lift. Yeah, I know… Thanks.
U
U Offline
I was lucky and had my torque tube to out when working on the Okie bushing. I just checked my support cross member and it does look like it can be remove. That might make it easier to work on the bushing. But, I have a '46 and probably not the same as yours.
~ John in Utah
Here We Go
Follow in his DITY Bay
You really need the puller to get the old bushing out. And I suspect the transmission would be in the way. You MIGHT be able to get the torque tube high enough to clear the transmission, but you'll be restricted in room enough to drive the new oakie bushing in place. I would remove the crossmember and support the torque tube below the transmission so you have adequate access.
I replaced mine while the engine and transmission were out and no cab sitting on the chassis. The crossmember was in place to support the torque tube.
Thanks. I do have the bushing tool to pull out the old bushing.
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.208s Queries: 14 (0.077s) Memory: 0.6101 MB (Peak: 0.6485 MB) Data Comp: Zlib Server Time: 2025-09-22 22:50:29 UTC
Valid HTML 5 and Valid CSS
