4 members (Hanks custodian, Ponchogl, Wayne67vert, 1 invisible), 175 guests, and 3 robots.
Topics128,089
Posts1,056,139
Members48,435
I am needing to replace sections of the windlace channel (not the rubber seal) and was wondering if there were any preferred methods. I was thinking of drilling holes in the center of the channel then spot welding. I am concerned about laying down to much weld then having to try and grind down in the channel creating a bigger mess. Anyone have some tips or another method?
Eric
1950 Chevrolet 1/2-Ton 3100
Eric - Here is a not to old thread on your topic that I think will give you good info on how to accomplish this without too much mess. wink
~ Dan
1951 Chevy 3 window 3100
Eric, that's basically the way I installed sections of windlace channel. Drill some ~3/16" holes, then line up the mig gun with the hole and pull the trigger for a few seconds. I did have to grind down a little excess weld. I used a 3" cutoff wheel to accomplish that, managing to stay between the lines so to speak.
Thanks Gdads51, I did some searching windlace retainer install last night but all the hits I opened were for the seal installation. This is exactly what I need.
Thanks Klhansen, I don't have a whole lot to replace so hopefully won't have to deal with too many bugger welds. I think the hardest part will be me being able to see down in the channel. My eyes aren't what they used to be.
Thanks again everyone
Moderated by  ndkid275, Phak1
