8 members (Mike B, WICruiser, Youngin' Tut 59, Pete1946, Bizaircon, klhansen, LuckyLee, 1 invisible),
72
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,140 Posts1,056,770 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 162 'Bolter | | 'Bolter Joined: May 2010 Posts: 162 | My wiper arm wore out. Ordered replacement arm. Blade was good. I can’t get the blade off of the old arm. Seems simple but can’t budge it.
Thanks Mark | | | | | Joined: Jul 2018 Posts: 72 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 72 | If like my 65 there is a small pin that holds them on .I think I used a small flat blade screwdriver to press or pry the piece that holds the pin. Don't know if that makes sense but can't remember exactly how it went. | | | | | Joined: May 2010 Posts: 162 'Bolter | | 'Bolter Joined: May 2010 Posts: 162 | Sheesh Had to almost take it apart. I’m buying the whole thing next time. | | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | It helps to pry up the small pieces that hold it in place. Then something really small can slide in easier to get it apart. Then pinch back down once new one is on. | | | | | Joined: May 2010 Posts: 162 'Bolter | | 'Bolter Joined: May 2010 Posts: 162 | It must have been stuck bad for some reason. It’s been a while but I’ve changed them before. Thanks all. | | |
