2 members (RLB, 1 invisible),
157
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2025 Posts: 6 'Bolter | | 'Bolter Joined: Mar 2025 Posts: 6 | Have been kicking around the idea of the swap on my 3800.
1) would retain 4 speed 2) slightly goosed gear ratios 3) reverse light switch already there
Is this doable without cutting up the floorboard? Or would the stick be further back? | | | | | Joined: Sep 2009 Posts: 5,886 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,886 | Matt - You can find some useful info from this long ago post about an issue with the SM465 not fitting the earlier bell housing opening without modification. If you want more details on comparing the two transmissions, look at: SM420 Info from NovakSM465 Info from NovakI don't know for sure on the answer on changes needed to your floor board/transmission cover, but from looking at the pics in these source documents, it's a good probability that some changes will need to be made. BTW - Since both transmissions have the same final drive output ratio (1 to 1), you aren't going to see any top end drive changes. I think the SM465 has a better 1st gear (6.55) VS the SM 420 (7.05) but otherwise you aren't going to see any big changes through the rest of the gears. There are also some considerations that may be needed concerning the output shaft on the SM465 as there were 3 different ones. Depending on which SM465 you find, you most likely will have some driveshaft modifications required. Others with more knowledge and experience with the SM465 will probably chime in here and offer further insight.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Sep 2011 Posts: 1,456 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,456 | Not much gain for the effort, plus you'd have to relearn where reverse is!
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | I have an SM465 sitting on the shop floor along with all the parts to bolt it to a SBC or a BBC for that matter. It's been sitting there for 20 years waiting for me to make the conversion or buy a later truck needing it. I though about adapting it to the 235 several times but it was soooo much easier to overhaul the SM420 that I never got around to it. I'm now old enough that I no longer see the point of either a V8 or the 465 adaptation. If it was a Spicer 5 speed OD, well then maybe... But then I can run 60-65 MPH all day comfortably now so what's the point. I long ago put a reverse light switch next to the mirror-heat switch with a couple of pilot lights. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Mar 2025 Posts: 6 'Bolter | | 'Bolter Joined: Mar 2025 Posts: 6 | The SM420 is coming out for a rebuild at best anyways, so a transmission has to go back in. As I'm keeping this a work truck and not looking for any radical gear changes (465 is reasonably close to 420), it might be in my best interest in swapping while I'm halfway there. Bellhousing to shifter is the make or break it number, unless I'm overlooking something else. | | | | | Joined: Sep 2009 Posts: 5,886 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,886 | Did you miss the note about having to modify the existing bell housing opening to allow the SM 465 to install? The opening on the 235 bell housing is too small for the SM465 and requires machining to fit the larger input shaft bearing collar.
| | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | Ditto on boring the hole bigger. It would require a BIG lathe, or a Bridgeport mill and a fly cutter to open up the hole in the bell housing to fit the bearing retainer on the 465 transmission. That hole must be bored concentric with the crankshaft centerline to avoid runout and vibration problems. Jerry
| | | | | Joined: Oct 2014 Posts: 142 'Bolter | | 'Bolter Joined: Oct 2014 Posts: 142 | I have done this conversion on one of my trucks and it's not really that hard but might be a little expensive depending on your access to a machine shop and driveline shop. Once you enlarge the hole in the bell housing the 465 will bolt in then the drive shaft will need to be shorten just a bit or I did on my truck. When you get finished underneath you will have to modify the bolt in portion of the floorboard. The 465 is taller and the shifter is a little father back. The SM420 is a good trans. the only reason I switched was I had a 465 on hand and didn't want to rebuild the 420. Hope this helps. | | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | Ditto on boring the hole bigger. It would require a BIG lathe, or a Bridgeport mill and a fly cutter to open up the hole in the bell housing to fit the bearing retainer on the 465 transmission. That hole must be bored concentric with the crankshaft centerline to avoid runout and vibration problems. Jerry I wonder if you could do it with a boring bar like we used to bore motorcycle cylinders with.Bolted it to the top of the cylinder. I had no trouble making the overbores concentric. I don't remember what the maximum capacity was but Harley cylinders are pretty big. Years ago the bikers across the road from me had cast up a cannon they used to shoot Harley pistons. I know this because one landed in my yard and when i took it back I was invited to share the keg. There was a jagged hole in the barn but the hay bales stopped that piston. They had enough home brewed beer to put put any fires.
1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Jan 2014 Posts: 3,688 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,688 | I have done this conversion on one of my trucks and it's not really that hard but might be a little expensive depending on your access to a machine shop and driveline shop. Once you enlarge the hole in the bell housing the 465 will bolt in then the drive shaft will need to be shorten just a bit or I did on my truck. When you get finished underneath you will have to modify the bolt in portion of the floorboard. The 465 is taller and the shifter is a little father back. The SM420 is a good trans. the only reason I switched was I had a 465 on hand and didn't want to rebuild the 420. Hope this helps. Is the input shaft the same length/diameter as the Sm420?
1951 3100
| | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | I wonder if you could do it with a boring bar like we used to bore motorcycle cylinders with. Bolted it to the top of the cylinder. I use a Van Norman 944S boring bar to counterbore the back end of a stovebolt engine block for a full circle lip seal to replace the rope seal by bolting a piece of 3/4" plate to the back of the block to support the boring bar, and using the rear main bearing bore for centering. I'm pretty sure you could do the same thing with the bellhousing. Jerry
