4 members (KEVINSKI, Guitplayer, Samantha, lumbersawyer), 109 guests, and 1 robot.
Topics128,154
Posts1,056,855
Members48,456
#1577943 05/22/2025 7:34 PM
My wiper arm wore out. Ordered replacement arm. Blade was good. I can’t get the blade off of the old arm. Seems simple but can’t budge it.
Mark
If like my 65 there is a small pin that holds them on .I think I used a small flat blade screwdriver to press or pry the piece that holds the pin. Don't know if that makes sense but can't remember exactly how it went.
1965 c-10 4 wheel drive conversion
Pix in the Gallery Forum
Sheesh Had to almost take it apart. I’m buying the whole thing next time.
It helps to pry up the small pieces that hold it in place. Then something really small can slide in easier to get it apart. Then pinch back down once new one is on.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
It must have been stuck bad for some reason. It’s been a while but I’ve changed them before. Thanks all.
