0 members (), 95 guests, and 7 robots.
Topics128,271
Posts1,058,313
Members48,485
#1577891 05/21/2025 11:18 PM
I'm going to put LED headlights in my 36, they have the turn signal inside the bulb. I can't seem to be able to fine a wiring diagram for the turn signal portion of the light. There are 3 wires for the headlight itself, High, low and ground. There are 3 wires for the t/s lamp. They are white, red, and black. Anybody know what wires I need to use for the t/s function? Thanks for any and all help in this small project wink The lights are United Pacific S2010LED
1936 GMC T-14 restro-mod
Also there is only 2 small holes in the base of the headlight bucket, just big enough to pull 2 18 gauge wires through. I don't have the conduit for the h/l wiring yet so don't know how big of a hole I will need to pull 5 or 6 18gauge wires. I assume these are the original buckets, they came with the truck when I bought many, many moon's ago.
Yours didn't come with instructions??
Thanks for the picture of the install directions. The box I opened did not have any paper work with it. I haven't opened the other one, maybe there is one in there. Any idea about the wiring conduit and the size hole in the bucket? There has to be something bigger than a couple of 1/8th inch holes for the wiring. I'll search some more and see if I can find a picture or something that shows this.
