4 members (Gdads51, 55shaker, 1955 1 Series, 1 invisible), 129 guests, and 3 robots.
Topics128,070
Posts1,055,900
Members48,429
Page 2 of 2 1 2
A few pics
Jeff
1964 Chevrolet K10 Fleetside
"A Kid's First Truck"
Follow in the DITY
1951 Chevrolet 3100
Follow his build in the Project Journals
1969 Chevrolet Camaro Convertible | 2020 Chevrolet Silverado | 3500 Duramax | 2021 GMC Sierra Denali
USAF Veteran 1983-1987 | PSP retired 1990- 2012
Another
Jeff
Follow in the DITY
1951 Chevrolet 3100
Could you tell me what your drivers side front shock to steering rod end is? I installed the Chevs of the 40's conversion kit which had no instruction and that is the only agp that i'm not sure about.
FOR YOUR INFORMATION since the Chevs of the 40s lacked instruction I took various measurement from two truck I located in close by garage.
Out truck is a 48 and your is a 51.
The front shocks are 12 inches. Mount to mount. Stock location. Not sure what your asking about referencing "steering rod end".
Jeff
Follow in the DITY
1951 Chevrolet 3100
Originally Posted by Crummy
A few pics
Hey Thanks Crummy! The measurements and pictures really helped out. I was going to locate my shock mounts further up the curve but saw where the bed cross sill is located in your 3rd picture so that put an end to that idea. I do find it interesting how that bed cross-sill right adjacent to the mount is only seated on one side. You would think it would have a wedge underneath it but I can see the 70 plus year wear marks in my frame where the one side wore into it. I guess it worked for 70 years so no need to create a wedge shaped shim for it now. Is there now bolt going through the cross sill into the fame? I assume not because I don't see a hole in my frame that location.
Based on your rear mounts I think the aftermarket rear mounts are wider so I need to factor that in as well, or reshape it slightly. I think they only sell the one mount style for both front and back because I have never seen a narrower aftermarket one like on yours.
BTW- love the stance on your truck and the flat finish. I also have a 3" sids dropped axle and posies all around. I do have 2" blocks on the rear as well but no sure I will need them.
Once again, thanks for the help. This group never fails to impress me with the knowledge and friendliness it provides.
1950 Chevrolet 1/2-Ton 3100
The blocks on the back will just be personal preference. Sid talked me out of them. Just comes down to if you want a tail dragger or not. Try them see what you think.
Next for me will be 3:55 gears.
Jeff
Follow in the DITY
1951 Chevrolet 3100
Glad you like the look of the truck. It gets a lot of looks and thumbs up. Thank you.
Jeff
Follow in the DITY
1951 Chevrolet 3100
That spare has seen better days.
1950 Chevrolet 3100 (Ol' Roy)
grin Yeah for sure. It holds air. It's an original 16 . Couldn't bring myself to part with it.! Hope I never need it.
Jeff
Follow in the DITY
1951 Chevrolet 3100
Page 2 of 2 1 2
