0 members (), 35 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#157482 12/24/2005 3:53 AM
There is a set of punches. The OD matches the ID of the hole and the punch has a point ground in the center so you can the center of the hole. Confused? You can drop the punch in hole(s) of the old part and mark it's center on the new part.
Larry
I don't own a vehicle that isn't old enough to drink.
#157483 12/24/2005 6:47 AM
Former Workshop Owner
Transfer punch or spotter punch / spotting punch is what I have heard them called. I believe transfer punch is the most common name.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
#157484 12/24/2005 8:00 AM
Thank You, gentlemen. Transfer punch it is, found them real quick using that. There's also variation called a "Titty" punch that looks interesting. 8^)
Larry
#157485 12/24/2005 8:00 AM
Larry,
Now you know the name..here is a tip on using them. Hit them ONCE lightly with a hammer, then remove the top piece and use a center punch to "make a lasting impression". The real cheap transfer punches can self destruct quite easily...look for a brand made somewhere other than India or China.
Stuart
Moderated by  MNSmith
