0 members (),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | There is a set of punches. The OD matches the ID of the hole and the punch has a point ground in the center so you can the center of the hole. Confused? You can drop the punch in hole(s) of the old part and mark it's center on the new part. Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Nov 2004 Posts: 2,399 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,399 | Transfer punch or spotter punch / spotting punch is what I have heard them called. I believe transfer punch is the most common name.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Thank You, gentlemen. Transfer punch it is, found them real quick using that. There's also variation called a "Titty" punch that looks interesting. 8^) Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Larry,
Now you know the name..here is a tip on using them. Hit them ONCE lightly with a hammer, then remove the top piece and use a center punch to "make a lasting impression". The real cheap transfer punches can self destruct quite easily...look for a brand made somewhere other than India or China.
Stuart | | |
