8 members (55shaker, Bruce 1954-4100, Hanks custodian, Gdads51, BC59, Cletus1950, cmayna, 3800GUY), 126 guests, and 1 robot.
Topics128,109
Posts1,056,253
Members48,437
#1573598 03/27/2025 12:06 PM
I purchased a tank from a friend for my 1946 Chevy truck 1/2 ton. (It's in much better shape than mine is.) I plan on running a vacuum around to get any loose debris out (it's been empty and un-installed for over five years, sitting inside of our pole barn), but is there anything else I should do to prep or clean the inside before we filter/seal/wire it? TIA!
1946 Chevy
Getting started on Bruno
You can't buy happiness but you can buy a truck ... and that's pretty much the same thing.
What is the overall condition? Are there any loose rust particles inside? If so, I'd purchase a fuel tank sloshing compound from Eastwood or similar and coat/seal the inside.
I've used those products successfully on two tanks and they held up for over 20 years.
Do you have a radiator shop near you? The one near me also boils out fuel tanks and then seals them on the inside.
1950 Chevrolet 3100 (Ol' Roy)
7
7 Offline
I agree, if it has rust inside, treat and seal. If it is smooth steel inside, rinse it with fresh gas or lacquer thinner.
U
U Offline
Thanks for asking this question. I like the idea of the radiator shop. I was planning to take my radiator and I'll check to see if they do gas tanks and maybe the heater core too.
~ John in Utah
Here We Go
Follow in his DITY Bay
Utah, what type of heater core do you have? Is it a little rectangle or is it the round one?
I purchased a new, round heater core assembly with the tanks, tubes, and mounting plate for $225 from Classic Parts of America. Other companies wanted $200 just for the round core with no tanks or tubes or mounting hardware. You would have to reuse your old tanks and mounting plate, etc.
@ Otto - The overall condition is really good! We moved it last weekend and heard a few particles, but we haven't opened it yet to investigate (we're on wiring right now). We don't have a shop nearby but I'll Google for the closest one. Thank you all for the recommendations!!
1946 Chevy
V
V Offline
You can clean out the tank with citric acid. I buy it in 20 kg bags, it's great for removing rust and dirt. You mix the acid powder with hot water. I use the 200 litre plastic drums that dairy farmers use. A pressure washer is used to rinse out the tank.
The POR 15 tank seal kit comes with a acid wash , first you clean the tank with the acid wash , then you use the special sealing paint .
1940 Canadian Chevrolet Series 13 (1/2-t) utility (Australian)
Lots of history here!
Read ot all in the DITY
you can buy a new tank for about $350 (at least I did a couple of years ago)?
Might be worth the cost?
I was contemplating using the old tank on my truck and looked at the sealing products available and decided that the cost of those versus a new tank wasn't worth the possibility that the old tank would have been too thin from inside rust when trying to derust and seal it. I had it in my garage till just last fall and took it out during a cleanup and discovered that it had indeed rusted through. I'm glad that I bought a replacement tank when I did on a road trip down south which saved the cost of shipping one up here if I had discovered the rust thru after buying the sealing products.
The tank in my 53 is in pretty nice shape. Just a little rust at the bottom. I took it out and put a couple of gallons of gas in it with a couple of handfuls of nuts and bolts. I put it in the bed of my work truck and drove around for a week or so. It worked well. The interesting part was when I dumped it out a quarter and silver dollar sized chunks of lead came out with it. I have owned the truck for 45 years. It's a factory tank. It must have been in the since it was made. I put them back in there just for sentimental reasons. I guess I'm running leaded fuel.
My guess is the nuts and bolts knocked those pieces loose. I'd be afraid that they might move around and block the fuel supply line.
U
U Offline
"46 Chevy truck" - Did you get your gas tank installed? Did you do any cleaning in the inside? If so, what route did you take?
~ John in Utah
Here We Go
