2 members (NJC, Otto Skorzeny), 67 guests, and 4 robots.
Topics128,263
Posts1,058,134
Members48,482
#1573540 03/26/2025 10:19 PM
Bought a project, passenger door is stuck shut, thinking just tight and maybe a little rust. I tried to force a bit but it seems stuck good. Any ideas on what to try? thanks
1946 GMC 1 Ton
1984 GMC 1/2 Ton
1996 Dodge 1/2 Ton
2014 Chevy 1/2 Ton
2020 Ram 1 Ton Cummins
FarNorth #1573542 03/26/2025 10:29 PM
What vintage truck? Have you tried both the inside and outside handles?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
FarNorth #1573545 03/26/2025 10:44 PM
O Online: Content
Can you get inside the truck at all? I assume it's the '46? Can you remove the door panel and get in there to see or work the mechanism?
1950 Chevrolet 3100 (Ol' Roy)
FarNorth - Since your topic is directly about "doors", your post has been moved to the Paint and Body Shop Doors sub-forum for further help and conversation.
Please come back and add more details about what truck you are working on and perhaps some pictures to help us understand and see what you are working with. smile
~ Dan
1951 Chevy 3 window 3100
I have tried both, it seems to be working judging by the feel of the handle when operating it, I may just have to remove the inside panel and look inside. It is on my 1941 Chevrolet pickup.
1946 GMC 1 Ton
1984 GMC 1/2 Ton
1996 Dodge 1/2 Ton
2014 Chevy 1/2 Ton
FarNorth #1574116 04/01/2025 11:21 PM
I went through this with my driver side door when I bought it. I ended up having to straighten a piece inside the mechanism. Works like a champ now.
I suspect someone tried forcing the handle when it was locked at some point. I added a pic with a red arrow to show where I heated it up a little and bent it just a touch.
1941 Chevy YR 1.5 ton Dump Truck
Follow this restoration in its DITY Bay
Semper Fi
