Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
8 members (Guitplayer, Possum, cmayna, Joe W, UtahYork, Greg_H, FAST55, rfs56trk), 522 guests, and 1 robot.
Topics126,776
Posts1,039,271
Members48,100
Most Online2,175
Jul 21st, 2025
#1573186 03/22/2025 9:29 PM
Moderated
Moderated
Greetings.
I just acquired a 1958 860 tandem axle truck. loose but not running yet. Couple questions... Where can I get info on this truck? Are there many around anymore? Parts? Thanks for any help!
agwss #1573191 03/22/2025 10:15 PM
Big Bolt Forum Moderator
welcome to the site! I am sure some of the guys with the bigger trucks will be along soon and be able to answer some of your questions. What kind of parts are you looking for? I am assuming the 860 is a GMC? You might put a little more info about your truck in your signature. Also, stop by the welcome wagon and introduce yourself
Mike
agwss #1573194 03/22/2025 11:01 PM
7
7 Offline
Welcome to the forums agwss, look for a shop manual for your truck, and a factory assembly manual. Also, check out the GM Heritage site, they have "Vehicle Information Kits" that give a boat load of info. A lot of members have Big Bolts and have done major work on them, ask questions and you will get answers.
agwss #1573195 03/22/2025 11:26 PM
Smaller model GMC trucks in 1958 had an ID plate on the left door hinge pillar that had the serial number and engine ID information. I don't know if that carried through to larger trucks like yours. Larger trucks had a similar plate on the inside of the glove box door that had the same info as the tag of the pillar plus additional info about the transmission and rear end.
Below is extracted from the 1955-60 GMC Master Parts Book printed 12/60 and covering 100 series (small pickups) through the largest GMC trucks made during those years . The "S" series letter defines 1958 and 59 models. I have the book in both paper and .PDF form. I don't remember where I got the .PDF file, but if you are interested I could try to find out.
agwss #1573207 03/23/2025 12:32 AM
Moderated
Moderated
Thanks for the info. I don't have the truck home yet but I'm sure I'll have questions. Thanks!
Welcome!
Post some pictures when you get it home.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
agwss #1573236 03/23/2025 12:44 PM
AD Addict & Tinkerer
In case you don’t know how to post pictures, here’s a link to instructions on how to add pictures to a post.
Phil
Project Journals
Stovebolt Gallery Forum
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.050s Queries: 15 (0.047s) Memory: 0.6178 MB (Peak: 0.7039 MB) Data Comp: Zlib Server Time: 2025-09-22 15:35:14 UTC
Valid HTML 5 and Valid CSS
