0 members (), 119 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,458
Pulled her out and no spark from points / condenser dizzy.
Never had any problems and never paid much attention until now.
Coil has 12 volt printed on the side and there is a ballast resister on the hot wire from ignition to coil. I assume the resistor drops it down to 6 v.
12v conversion
Question:
Is this resistor necessary and if so why as the coil is 12v?
1954 Std Cab 3100 w/ 2 spare Engines
IL
1954 three window 3100
Sir Searchalot
Sir Searchalot
Yes
On a 12V system there is "bypass" wiring necessary. So the 12V coil has two inputs to indirectly power the points.. A full 12V input when starting because the starter draws so much and will rob the points of voltage/current. Then after start. the points run on a reduced/resisted voltage off the ballast input so they don't burn out.
So during start you "bypass" the ballast. Ballast drops voltage to approx 9V.
This is all accomplished by a side terminal on a foot starter switch OR an "R" terminal on a solenoid starter OR by an ignition switch with Ign 1, Ign 2 terminals.
A few years used a Looooooong folded "resistance wire" instead of a ballast resistor.
Its been a while since we have seen you around.
Can you give us a quick refresher on what engine you are working on?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
yes, its been a while. I have been lurking in the shadows. Now that I’m retired, i have more time and a 401k to play with.
Life has been interestingly problematic!!!
Sadly, the only work i’ve gotten done was to rebuild a bench seat using plywood and foam and refreshing some stock wheels. However, i have been in lots of parades!
I do believe Bartomas has answered- thanks much
Anywho, bartered my 51 away and still have my first, a 1954 3100 w/ 235 ci and a SM420 behind that followed by 3:55 in the third member. absolutely no plans on changing that. I even picked up a pair of 1954 235 power glide engines (which I hope to never have to use but they were free and wouldve been scraped)
I’m going to have a blast this summer tackling all the nagging problems plus desired upgrades.
IL
