Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
6 members (niobrarafun, RBs36, Otto Skorzeny, kades51, Guitplayer, MNSmith), 567 guests, and 1 robot.
Topics126,778
Posts1,039,291
Members48,100
Most Online2,175
Jul 21st, 2025
U
U Offline
I was just test fitting my intake/exhaust manifolds on my 1960 235. The front and rear have a guide pin for the exhaust manifold. Has anyone taken these out and replaced with studs to get a better seal after tightening? If so, do they just screw out?
~ John in Utah
Here We Go
Follow in his DITY Bay
The design idea behind using the pins is that the manifold expands in length (mostly front to back) between non-running cold conditions and running hot conditions. Using a bolt on the ends could cause the manifold to warp, creating leaks. I'd stay with the pins.
Replacing those pins with studs/nuts can also lead to cracked manifolds. dang If the manifold faces are in good shape and even across both intake and exhaust, you should have no problems with sealing when properly installed. wink
~ Dan
1951 Chevy 3 window 3100
U
U Offline
Thanks Bill and Dan! I'm learning all the time with the help of Stovebolters like you guys!
~ John in Utah
Here We Go
We all are. Thanks from me too
1950 3100w/63K
Farm Truck: Fame-up restoration / modification
Follow the restoration story in his Project Journal
1950 Styleline Deluxe Coupe w/93K
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.154s Queries: 15 (0.056s) Memory: 0.6171 MB (Peak: 0.6784 MB) Data Comp: Zlib Server Time: 2025-09-22 17:59:54 UTC
Valid HTML 5 and Valid CSS
