2 members (mick53, 37 GC), 151 guests, and 2 robots.
Topics128,147
Posts1,056,797
Members48,454
#1572195 03/10/2025 2:46 PM
Manifolds, transmission cases, etc…..
Any tips on what concoctions, methods work to get it brightened up? Better off to just paint it with a quality aluminum paint? I don’t own any sort of blasting equipment to go that route.
“Aluminum brightener” is a pretty common recommendation. Seems to be just some sort of acid treatment. Wondering if there’s a household equivalent. I also wonder if will just oxidize and look the same after a few months.
1951 3100
Wire wheel / wire brush. Then clear coat it if you want it to stay that way.
1950 Chevrolet 3100 (Ol' Roy)
H Online: Content
Once the surface oxidation is removed with a wire cup brush on a drill motor or an air die grinder, Use "Mother's" aluminum polish with a wool buffing pad- - - - -the same stuff the show and shine guys use on polished aluminum wheels. Then clearcoat to prevent further oxidation.
7
7 Offline
20 years ago I used "Eagle One mag and wheel cleaner" on my Vette factory wheels. They were dark and kinda' rough from oxidation. The wheel cleaner was aggressive enough to get back to bright aluminum without causing damage, I then used a "Mothers power Ball" with Mothers polish to bring some luster back. I didn't clear coat them, the Vette has a home in the garage so it doesn't get bad weather, the wheels have held up remarkedly well. I just wash the wheels with normal car wash detergent along with the rest of the car.
I hear Blue Magic works wonders, and it has a protectant in it. I’d only use it on bare metal. I had a crazy brother that used it on his black car once. Super shiny for a brief time, then went cloudy. I guess it eventually reacted with the paint. I just use Mothers and the ball on aluminum. Rough surface I’ve used 600-800 grit wet up to 2000, then polish.
Chip
'Rusto-Mod'
'51 Chevy 3600 5 window | C4 Corvette front/rear suspension & drivetrain | everything else looks old and stock
'92 GMC Sonoma GT #15 of 806
'91 GMC Sonoma GT Extended cab 1 of 1
Trucks, Trucks.....and more Trucks
I still use the aluminum wheel cleaner for getting cast aluminum bright. There are too kinds, one for clear coated wheels and one for plain cast wheels. I have only ever used the stuff for plain wheels. I do not know how well the other stuff would work on plain cast pieces.
Mike
