3 members (Hotrod Lincoln, joe apple, Wayne67vert), 119 guests, and 2 robots.
Topics128,142
Posts1,056,490
Members48,442
#1571732 03/03/2025 11:47 PM
I’ve attempted to replace the capillary tube and sending unit on my original gauge using a donor gauge. YouTube has a couple videos on how to do it using a section of copper tube from an oil pressure line as a slip sleeve soldered in place.
Has anyone done this successfully??? I keep getting a small pin hole on the last joint where I can smell the Ether leaking out. Maybe I shouldn’t use flux core solder?
During the process the sending unit is submerged in ice water to draw all the Ether to the bulb.
If I could find a good usable gauge with a good capillary tube I would abandon the fix attempt.
Any help is greatly appreciated.
Bob
1946 Chevy 1/2 ton "patina" pickup with a 1953 235 engine, otherwise all stock and unmolested!
How do you know the correct amount of ether?
I don’t. The donor gauge is a fully functional gauge that you cut the tube up near the gauge while the bulb in in ice water so you don’t lose any Ether.
7
7 Offline
Ice water may not be cold enough to keep the ether in 100% liquid state. If it is vaporizing/boiling at even the smallest amount, it will create pressure in the tube/bulb/bourdon tube and purge out of the liquid solder. Try dry ice for a colder bulb.
In the videos it shows ice water with rock salt. Another fellow just has the bulb in the freezer while doing the soldering. So may the freezer is better but yes, dry ice might be the perfect solution.
I really want this to work because so many of us have inoperable temp gauges for one reason or another and this way we can salvage a vintage original gauge!
H Online: Content
Dry ice and alcohol is the way to do that job. That's how we installed huge brass bushings in tire curing presses- - - - -ones over 12 inches in diameter and 6 inches wide. We would soak them in several gallons of alcohol in a metal trash can, with 20 pounds of dry ice in it. Those bushings would shrink about 1/4" in diameter and we would quickly insert them into a hole in the press frame. Then a big bull gear that closed the press down to cure the tires would be reinstalled.
Ice water is only 32F, but if you add rock salt, that mixture is 0F. Dry ice and alcohol is -130F, which is getting to the melting point of ether which is -177F. That will get the vapor pressure low enough that it won't blow the solder out of the joint.
Thanks KLHansen
That is what I was needing. I hope this works.
7
7 Offline
I have no experience soldering a vessel containing ether but I would imagine that any vapor pressure would increase with the heat from the soldering process, it may still present a problem at the last solder joint?
Moderated by  ndkid275, Phak1
