2 members (Hush, delky), 141 guests, and 0 robots.
Topics128,126
Posts1,056,354
Members48,441
#1571570 03/01/2025 4:05 PM
Hi everyone. Hope someone can help with my horn button problem.
The hole in the steering wheel only accepts the older style 6 volt connector. That’s the spring looking one in the picture. The one on the right is what is called out for the 12 volt. Only problem is the hole in the steering wheel is too small.
I’m thinking of drilling it out to fit the new one but wanted to get some feedback from anyone who has had experience with it.
As always I appreciate all the help I’ve gotten so far.
Doug
1954 Chevy 3100
One problem solved doesn’t seem to shorten the list
Montgomery, AL
In Project Journals
T-Doug #1571576 03/01/2025 4:51 PM
Former Workshop Owner
If you decide to drill it bigger, I would measure the diameter of the hole before you drill, just in case you need to put it back the way it was.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
T-Doug #1571587 03/01/2025 6:23 PM
That original contact shouldn't care about voltage. Try it and save some extra work.
Fred
rfs56trk #1571590 03/01/2025 7:35 PM
Fred
Agree.
T-Doug #1571604 03/01/2025 11:37 PM
Doug - I would also agree. If the existing contact has continuity between the brush end and the upper contact, it should be ready to do it's duty and no mods to the steering wheel needed. If there isn't continuity, lots of of NOS GM# 759037 horn contacts available on evilbay. wink
~ Dan
1951 Chevy 3 window 3100
T-Doug #1571608 03/02/2025 12:09 AM
O Online: Content
Doug, I purchased a 6v horn contact bushing (as it's described in the catalog) for my 1950 from NPD. It fit in the hole properly.
Part # K-2819-47B replaces GM #768233
1950 Chevrolet 3100 (Ol' Roy)
T-Doug #1571637 03/02/2025 3:14 PM
Thanks guys. I’ll work it out. My problem is when I assemble it the horn stays on.
I’ll update as I try some ideas.
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1571638 03/02/2025 3:19 PM
Don't forget to clean the contact points on the older set before you reassemble. Also the top edge of the steering column.
Craig
T-Doug #1571648 03/02/2025 4:46 PM
Doug, Does your pictured original contact set include a plastic sleeve??? According to the parts books, that earlier design original contact came with a separate plastic sleeve (like the bit surrounding the metal parts in the other contact you have), but it has a smaller diameter to the sleeve than that reproduction/replacement contact. GM# 759230 is the separate "plastic sleeve" for your old contact and should slide right into the existing steering wheel hole. I think that being absent is what's causing your horn to sound as the old contact isn't held in place correctly to prevent ground contact.
~ Dan
T-Doug #1571652 03/02/2025 5:00 PM
Might be able to find an appropriate "plastic sleeve" at McDonalds.
T-Doug #1571714 03/03/2025 7:51 PM
Looks like the sleeve is already in place. I’ll check it out when it warms up a bit.
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1571756 03/04/2025 2:36 AM
That is soooo unreal for as I was looking at T-Doug's original pic, I was wondering where is the original sleeve? Still in place?
Craig
