Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (ShopRag, 46 Texaco, Shade Baby), 147 guests, and 5 robots.
Topics128,283
Posts1,058,521
Members48,490
#1571468 02/27/2025 8:00 PM
I'm thinking about installing a 3 or 4 link suspension on my 46 1/2 ton with stock frame. I iinstalled a 292 engine and a 700r4 trans. And didn't have too much problem. I don't know how difficult it will be to install one so I could use some advise and maby some pictures if possible. Thanks Don
What is your end goal? Do you want it just for because (which is a valid reason)? Are you trying to address a handling issue?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Authorized Pest
Authorized Pest
P Online: Content
This looks like a good topic for the HiPo area. I'm gonna move it over there. wink
~ Peggy M
1949 Chevrolet 3804
"Success comes in 'cans' ..."
I’m going to do the same thing behind my 292 and M21, so bought this book. There are also about a million videos in the University of YouTube.
1950 3100w/63K
Farm Truck: Fame-up restoration / modification
Follow the restoration story in his Project Journal
1950 Styleline Deluxe Coupe w/93K
Why reinvent the wheel? The original leaf spring design has worked for a few million of these old trucks for the past 75 years or more. Change just for the sake of change doesn't make good nonsense. What kind of racing are you planning on doing?
Sir Searchalot
Sir Searchalot
I realize you just asked how to do it and not should I do it. It's really hard not to think we should save you from what many feel is a waste of time and money. So anyway........the answer was given, study the internet. Which you are doing here in the HiPo shop. As said, there are many videos and various kits. Some may be bolt on, some may need welding. You will need to de-rivet some things. The companies have good instruction. Just be sure they support a 1946 pick up. Good if members here have done this to that era.
The opinion aspect:
1. As you can start to see it's the same answer as when you asked about coil over shocks in rear and decided not to do that.
2. Yes, 4 link is a HiPo upgrade and belongs in the HiPo shop.
3. A 46 pick up with a 6 cylinder is not a HiPo vehicle. Albeit a 292 is a big 6. Hence why some are asking what your goal is.
4. I don't know what rear end you have but you don't have a muscle car, a street racer, tuner or a drag truck.
5. You may be like all of us, we've had SBC and BBC and still like that experience for sure. It's fun to build a DIY "performance" car/truck. Most of the Stovebolt is old trucks kept mostly original and some restomods. But we do have a HiPo shop and plenty of help.
6. If you are leaning to a performance truck, you need a V8. That's what you start with. To make a 6 into a "performance" motor that will "move" a 46 truck into High Performance. you need money and a lot of work. A V8 is already there and plenty of easy/cheap upgrades.
7. The members here in the HiPo Shop will be glad to help you do whatever you want to do. Again, I realize you just asked how to do it. So we can stick to that. (unless you wish to discuss the cost/performance "benefit" of doing 4 link in your case)
8. A 4 link is to handle Hi output speed and acceleration. Overall handling and "stability".
A 46 frame has a lot of flex built into it so that it gives instead of breaks on the rough roads that these trucks were driven on when they were new.
Newer trucks and cars which came 4 link suspension had rigid frames.
You will want to take that into consideration when you get into the engineering phase of your build.
