8 members (Wickedbass, MNSmith, 2-Ton, JW51, Maybellene, Hotrod Lincoln, 2 invisible),
88
Mod | | | Forums66 Topics128,042 Posts1,055,595 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 332 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 332 | So I put the felt strips in my drivers door and I slid the glass in and tried to move it to the top of the door. I got it there but it was with a lot of 2 hand persuasion. I know if I hook up the window regulator it won't be able to move the glass up or down. Any ideas as to how to remedy this? Thanks for any ideas or procedures to fix this problem. I only did one door and want to figure this one out before I do the other door.
1936 GMC T-14 restro-mod
| | | | | Joined: Feb 2019 Posts: 4,472 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,472 | Something is too tight. The glass should slide up and down fairly easily. I would check if the felt you used is correct for your application.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Oct 2012 Posts: 332 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 332 | Well I finally got the window to go up and down easily. I took a piece of 1/4" round stock and chopped off a piece about 4" long and then took another piece and welded it together to make a "T" handle and I then gently knocked it into the channel to help open it up, that worked pretty good but still tight in one spot, and I then took a "C" clamp and pulled the one slide bar over toward the door jamb and that fixed it . Slides up and down great now.
| | | | | Joined: Feb 2019 Posts: 4,472 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,472 | Good news and good thinking. Thanks for the followup!
