Winter is Coming
A good Tech Tip WINTERIZING YOUR TRUCK including a link back to the Forums for additional tips.
There appears to be another bolt hole below the bolt that’s holding the alternator bracket. Does it have or need a short bolt similar to the two bolts on the opposite side of engine? Also, if you are sure the timing cover seal was leaking, I read that on older bbc engines , guys were drilling dowl holes in cover out slightly. Then install timing cover with bolts loose, install balancer, then tighten timing cover bolts. Helps make certain seal is evenly centered on balancer. Also , in conjunction with that, some were installing a ready or speedy sleeve on balancer to slightly increase tension on lip of seal. One last thing, are you certain of the capacity of your oil pan? That it’s not being over filled. Some of those 396 pans were only 4 qt capacity. Good luck with it, you’ll find the solution eventually.
1966 C-10 Short Stepside HiPo Step-by-step ~ and on-going resto build in the Project Journals
Any chance the oil is coming out of one of the holes in the end of the heads? In the pictures the passenger side lower hole looks black whereas the rest appear to show some brightness. Doesn't seem like it would have anything to do with higher rpm, going up hill but a small leak in that area will have oil all over the place given the amount of air movement in the area.
Thanks for the suggestion... much appreciated. Those holes are accessory mount points and dead end.
Thanks for the suggestions...they are appreciated. Driver side bolt is a dead end hole. Dampener is new and has no groves worn into it, shouldn't need a sleeve. Oil pan is aftermarket and I will be underfilling after the gaskets replaced.
It was running great end of last year and the beginning of this year. One trip up to 6k rpm and it started being a pain. Unfortunately it doesn't want to comply.
So… went out and cleaned the oil off the truck. Took it for a spin and it still leaks… crawled under it and found a light drip between the pan and balancer.
New oil pan gasket arrives Monday… so with nothing to lose, figured I’d check the pan bolts again. Front 2 took a few turns each and I saw the pan suck up.
Tomorrow I’ll clean it up and test it again. Potentially light at the end of the tunnel
It appears that my oil leak issue has been resolved... for now
Perseverance is a great tool to have in your toolbox! Good Job!
Phil Moderator, The Engine Shop, Interiors and Project Journals
1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc Brakes Project Journals Stovebolt Gallery Forum
Packed and ready for the 2025 BC dragit challenge. First stops, coffee shop, second fuel, last one is the ferry before hitting the mainland.
Picked up new front tires, went down to a 70 series sidewall. Handling seams a little less twitchy but that could also be going to a different brand. So far so good with a 205/70R15
Just got back from roughly 3000km of drag and drive. Truck did well, lost one alternator bolt and sheared the rear driver side shock mount. Thankfully the shock left the building after the racing was done and somewhat close to home.
As far as times… truck ran pretty consistently in the 8.4-8.7. Only exception was a track at 4400 feet of elevation, ran a 9.36.
Most of the mph was in the low 80’s. Being so far from home I was hesitant to load the converter more than 1k rpm and the 60 foot times were mostly in the 1.9’s.
Had a blast and would do it again without hesitation. Still have some things I’d like to improve on the truck but it’s getting there.
Drag radials were mounted on a set of lightweight aluminum wheels for track use only. Switched back to torq thrusts once we were ready to hit the road.
That was a great reaction time on the first Time Slip, you had a better ET and speed on your second run. Very COOL...
~ Craig 1958 Viking 4400 "The Book of Thor" Read the story in the DITY 1960 Chevrolet C10 "A Family Heirloom" Follow the story in the DITY Gallery '59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting)
I noticed your wipers. Is that where the 1940 wipers park when off?
1950 Chevrolet 3100 (Ol' Roy)
Yup, shock mount broke off on the way home. The wipers don't have a park mode, they basically park wherever I shut them off. Depending on which photos you look at they will appear parked in different positions
The videos and still pictures are outstanding! Even with the shock mount break, clearly a great time was had. Am sure you'll have that fixed in no time at all!
~ Dan 1951 Chevy 3 window 3100 Follow this story in the DITY Gallery "My Grandpa Carl's Truck and How it Became Mine" 1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
Lost one shock mount on the drivers side and it looks like the passenger side was ready to go. Drivers side looked like the metal plate sheared, passenger side bent the metal shock bracket downward. Guessing the driver side also bent prior to breaking.
Passenger side shock is still tough to compress while the drivers side seams nearly shot. Not sure why that’s happening.
Do you think during launch it's squating the tail end, driving the shocks to full compression, and beyond ?
Chuck
Could be… I rewatched some of the videos and the slapper bars are moving upwards in a hurry. Truck is launching harder than I expected.
Originally Posted by DennisM
I added these snubbers to limit the travel. My springs are softer and added adjustable overriders for heavy loads.
Dennis
Thanks for the tip… if I keep running it at the strip I’m going to need to do something.
There is also the possibility that my original math on shock size was off.
Anyway, oil change and new plugs were this weekends chores. Plugs mostly look ok… somehow it’s tough to get good plug pics 😄 I’ve been avoiding changing plugs since they’re a complete pain to get at… my hands and arms look like I lost a fight with a rabid raccoon.
My buddy from the drag and drive left me some shop wipes.. can highly recommend this brand. Work really well
The plugs all look pretty good. Number 8 is a little darker, that could just be the picture though. If your traction bars are moving a lot, you may want to add a taller snub to the end or space them up closer to the spring pack.
Couple of minor updates... I've put a thousand km's on the truck since the drag and drive. Little carb tweaking and the hot idle afr is now in the 14.2-14.6 range. Cruising afr is a little lower than I'd like but it's a work in progress After unsuccessfully trying a few different one piece oil pans that all had minor leaks if one sort or another.... I ended up with Mr. Gasket Oil Pan Gasket 6663G. So far so good
The not so good is that the constant 6k shifts at the drag and drive has killed my water pump bearing.
Just a thought here. If you plan to continue Drag Racing the truck, you might look into an electric waterpump. It would help with cool downs after the runs as well.
Not sure what I'm doing with the truck, other than expecting way to much from it. It's currently a long hauler, local cruiser and a drag truck.... none of which it excels at
When I put the truck together it was more a mindset about being sort of "cool" rather than functional. It feels like I'd be losing the mid 60's hot rod feel once I start targeting a specific use.
At some point my C3 will be finished and that should spell the end of the trucks long distance days.
Turns out it was the alternator bearing that went out not the water pump. With the mechanical fan it's nearly impossible to hear anything inside the engine compartment. Took the fan off, spun the water pump and it sounded good, tried the alternator and heard a "squeal". Replaced the alternator with my spare and it appears to be all good again.
While putting it all back together I thought I'd experiment without running the mechanical fan. Truck idles around 650rpm so how much air could the 15inch mech be pushing? Last night I went to a local cruise/rod run with roughly 150 other cars for a 1-1.5hr drive, some highway but mostly back roads and subdivision driving. Weather was around 21C.
Turns out the 10 inch electrical fan set up as a pusher struggles on it's own without the mechanical fan running in tandem. Truck mostly ran 190-200, hitting 210 on a slow uphill crawl.
The truck is so much quieter without the mechanical fan that I'm going to try running a 14inch electrical puller fan and see what happens. I'll be keeping the 10inch installed and throw the mechanical in the truck box for just incase moments. I know the small electric and the mechanical work well in tandem so if it's necessary I can always go back.
Didn’t take long to scratch and dent the bed wood… again. Put some blankets down but the corvette door dug in.
Have been playing with the steering box and ended up with a combination of 75-90weight gear oil and some multi purpose grease. Steering is smooth but there’s a vagueness in the feel.
Was adjusting the rear brakes today and had a thought.
I suffered a broken rear shock mount after the drag and drive and wasn’t sure why.
It dawned on me today that part way through the drag and drive, I started jacking the truck up by the shock mount tab. Now wondering if that’s what could have been causing the metal fatigue.
Also went through the steering and tightened up all the nuts/bolts. A few had worked themselves loose.
Not a lot of updates for the build....I noticed some white milky fluid on the air cleaner and the drivers side valve cover a couple of times late in the year. It looks like my radiator is on the way out. Upper left corner where the tank joins the core is weeping.
I picked up another champion since it cooled the truck extremely well and in all fairness I did beat the radiator up pretty good...awhile ago I bled on the horn button and it left a stain of sorts. No gray paint on the shelf but I did have some metallic hi-temp silver available...turned out pretty decent
Some changes coming for the truck this year. According to the calculators a .68 5th gear will drop my highway rpm from 3000 to 1700 at 60mph so it's time to start collecting parts for a planned TKX swap.
Picked up a speedometer from a 40 chevy car on eBay to replace the one I destroyed by dismantling my original one. According to some online research the car and truck units are the same.
Funny, my pencil and paper says that 3000 x 0.68 = 2040 rpm.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
Speedometer is in and sort of functional. Testing last night revealed that the Speedo or the speedhut gps box is sensitive to bends in the cable.
I have a short ish 38inch speed cable but that’s a bit long with the gps box mounted to the back of the glove box. Also dug out my 90° adapter to help straighten the path between the two.
As always it’s a work in progress
Got the speedo mounted and tested… greased the 90dg fitting and the cable with white grease. It spins the speedo up nicely.
Working on the rad replacement and figured out why it was spewing liquid. The front side looks like it was used for target practice, with multiple through holes in it.
The aluminum might be a bit soft and I’ll probably need to look at putting some type of mesh screen in front of the new one.
