5 members (Barry Martak, J Lucas, rfs56trk, Otto Skorzeny, 1 invisible), 86 guests, and 2 robots.
Topics128,094
Posts1,056,487
Members48,444
Anyone used a modern equivalent (Industrial Supply?) for replacing front drum brake bearings? What I have are New Departure 909801/909701 outer bearings, will check the inner later. Just wanted to see if anyone has replaced them with a modern equivalent. I know you can get some from dedicated AD truck suppliers but they are an arm and leg, but some other antique car forums have suggested trying Industrial Bearing Suppliers where they are as much as 1/4 the price.
I've been wondering that as well. There's a bearing supply house here in town that I think could cross them over. I have a set of the ball bearings from a 1953 3100 that they might be able to get dimensions from. I just haven't had the inclination to do that, as the bearings on my truck are doing OK. I think part of the issue is the inner bearing has an extended portion where the grease seal runs. It might be possible to replace that with a simple spacer of the right dimensions.
I have pulled the bearing out of mine and cleaned with diesel to get the 75 year old grease out. The brake cylinders were gummed up with rust also and not working, so I thought I would look at replacing them since I was this far in…
Look up some previous posts the numbers are in some of them,would need to double check though.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
U
U Offline
I have a '46 and those are the numbers on my bearings too.
~ John in Utah
Here We Go
Follow in his DITY Bay
Thanks guys appreciate the feedback
The AD bearing dimensions are fairly oddball. I’ve looked into it. Best I can tell, the only available modern roller bearings were made for this very purpose.
You don’t necessarily “have to” source from specialty vendors. These were produced many decades ago, and NOS examples are on eBay. There is some cross over to other GM vehicles (I can’t remember if it’s inner, outer, or both), so these aren’t as scarce as one might assume.
1951 3100
The "R" in 909052R and 909067R specify a ROLLER type aftermarket bearing. The original parts were BALL type bearings with numbers of 909052 and 909067. Nothing wrong with either type as long as you use the proper adjustment procedure for the bearing type.
