3 members (tesa, 55shaker, Bill Hanlon), 58 guests, and 0 robots.
Topics128,076
Posts1,055,924
Members48,430
#1569789 02/06/2025 1:54 AM
How far can you you bore a 350' chevy? I see they make .060" .080" and .100" pistons..
Ol'55 #1569790 02/06/2025 1:57 AM
Depends on the year of manufacture. Newer ones- - - - -1970 or later, are probably pushing the envelope at .060. I used to buy "worn out" 60 over race blocks and put my high school machine shop students to installing 8 sleeves as shop projects. After a while some of my competitors realized that they were getting beat by their own junk!
Ol'55 #1569797 02/06/2025 3:39 AM
Hey there Jerry it is a 69' 4 bolt main with a Steel crank.
Ol'55 #1569799 02/06/2025 4:06 AM
That's right on the ragged edge of the "thinwall" block changeover- - - -not sure which way a 69 would be. 60 over is as far as I like to go, unless I'm building a short life engine. We would go through 2-3 engines a season on the dirt tracks- - - -with more clearance built into a brand new one than a 100K mile street engine. A round track engine with 1K miles on it was an antique! If you have a little extra piston skirt clearance on a 60 over engine, consider maybe putting a knurl on the piston skirts to get the clearance right, and do a hone and re-ring job. If there's less than .005" taper wear in the top 2 inches of the bore (and no score marks), you can do a re-ring without boring.
