5 members (diseasel, Bill Hanlon, 59 fleet, Phak1, Wayne67vert), 109 guests, and 1 robot.
Topics128,035
Posts1,055,566
#1569766 02/05/2025 9:47 PM
So I put the felt strips in my drivers door and I slid the glass in and tried to move it to the top of the door. I got it there but it was with a lot of 2 hand persuasion. I know if I hook up the window regulator it won't be able to move the glass up or down. Any ideas as to how to remedy this?
Thanks for any ideas or procedures to fix this problem. I only did one door and want to figure this one out before I do the other door.
1936 GMC T-14 restro-mod
FAST55 #1570123 02/11/2025 2:07 AM
AD Addict & Tinkerer
Something is too tight. The glass should slide up and down fairly easily. I would check if the felt you used is correct for your application.
Phil
Project Journals
Stovebolt Gallery Forum
FAST55 #1570583 02/17/2025 11:22 PM
Well I finally got the window to go up and down easily. I took a piece of 1/4" round stock and chopped off a piece about 4" long and then took another piece and welded it together to make a "T" handle and I then gently knocked it into the channel to help open it up, that worked pretty good but still tight in one spot, and I then took a "C" clamp and pulled the one slide bar over toward the door jamb and that fixed it . Slides up and down great now.
FAST55 #1570584 02/17/2025 11:27 PM
Good news and good thinking. Thanks for the followup!
Phil
Project Journals
Moderated by  ndkid275, Phak1
