7 members (55shaker, cmayna, walter74, greenie-reddy, Peggy M, Otto Skorzeny, Ponchogl),
186
Mod | | | Forums66 Topics128,114 Posts1,056,282 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2023 Posts: 11 'Bolter | | 'Bolter Joined: Sep 2023 Posts: 11 | Hey there,
I'm putting a 261 together and need a carburetor for it. I've read that the 261 carburetor is slightly bigger than a 235 carburetor. All of the reman units i find listed for sale are for 235/261. So my question is would a reman for a 292 be a better option and will it bolt up to the 261?
Thank you!
| | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | The only carburetor I'm aware of that was specifically designed for a 261 was a Rochester B with a slightly oversized venturi to accommodate the extra displacement. Those carbs are scarce, and they have a host of design problems that haven't gotten any better with age. Try to find a Carter YF calibrated for an AMC/Jeep 258 cubic inch six. It will have the same manifold stud spacing as the Rochester, and it's a much better design. The 292 carb would run pretty lean without some major rejetting. Jerry
| | | | | Joined: Sep 2011 Posts: 1,456 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,456 | I ran a "B" from a '67 292 on my 261 for awhile, as HRL states, I had to dink with bigger jet but it ran pretty well. I would agree, find a Carter YF calibrated for an AMC/Jeep 258 cubic inch six.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | I have 2 Rochester Bs made for a 261 and both have warping issues that cause internal and external fuel leaks. Also, there is some wear in the accelerator piston bore. I am one of those who is not fond of the B, so I decided to use something else. Heads-up info:
In 1960, the design of the Rochester B changed to a different mechanical connection for the air cleaner. The Carter YF for Chevrolet changed as well. This is just one of the "gotchas" that you can run into when looking for a different carburetor for a 261. You also can have throttle linkage issues such as type of bell cam, on the engine. Then there is a difference with the Carter YF models (Chevrolet, GMC, Ford, Jeep etc.) where throttle arm up = throttle valve open versus throttle arm up = throttle valve closed. Then another carburetor issue of ported versus non-ported vacuum connections for the distributor timing advance. Then some of us prefer a manual choke carburetor for our "Stovebolt" engines. It's not fun to spend $$$ on a rebuilt carburetor only to run into the adaption problems. Homework is required. If you are rebuilding your 261 then you need a known good working carburetor before attempting the engine break-in run.
I have a Carter YF 2100 on my 261 in my 55 1st. Cold cranking is excellent even after a month of sitting. The only issue is that it was designed for a 235 engine, and you lose a little bit of power going uphill full throttle.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | |
