2 members (BC59, cmayna), 63 guests, and 4 robots.
Topics128,188
Posts1,057,215
Members48,465
0
0 Offline
I just pulled the head off my 54 model 248 and pressure washed it before taking it apart. After washing , I was going through the manual and saw a mention of caps on top of exhaust valve stems, but didn’t see any during disassembling or clean-up. Do all 248's have these caps on exhaust valves or just some models. I usually notice things like that, but was in a hurry and could of missed it. Thanks for any information.
There was a rotator cap used on some 248 exhaust valves. (see attachment)
Intake valve springs had an "oil shield" over the top of the spring.
0
0 Offline
Thanks for the reply Mr. Bill. That’s what my book shows too.
I didn’t know if they were eliminated by the previous
Owner or I lost them in my wash down ( pressure
Washer). Or maybe GM eliminated them after the
Book was printed.
I don't think these caps were on all engines. Seems to me like they were on larger trucks only, but my '39-54 Master Parts Book doesn't show them at all. GiantMountainKiller (Kenneth) will know.
All of the 270's and 302's I've torn down have them but I'm not sure about the smaller ones.
If you want to run exhaust valve rotators for some reason, it would probably be possible to adapt the ones that fit 305 or 350 Chevy V8s to the GMC valves. It might be necessary to use a slightly shorter free length valve spring with the rotators.
0
0 Offline
From the wear marks, it doesn’t really look like it had them.
I think I’ll just go capless, shouldn’t hurt anything I
Guess. Thanks for the reply’s .
