8 members (Joe H, Joe Lowe III, frogfarmer, Shade Baby, 3B, Oswald, Cosmo, 1 invisible),
66
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2025 Posts: 40 'Bolter | | 'Bolter Joined: Jan 2025 Posts: 40 | Those sites that sell the cab corner replacement panels advertise them as being for the 47-54 pickups. Will those same ones work on the Loadmaster COE model or where can I locate the ones for this truck? I see some are much larger than others too. Just wondering the different uses for that. Thanks | | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | From what I can tell by looking at the 47-54 Factory Assembly Manual figures, the rear of the cabs for the COE should be the same as the pickups. The differences are at the cowl areas and the doors. I think you could get cab corner panels for the pickup and use them on your COE cab. Like all patch panels, you may find that they need a little massaging to fit correctly.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | If they are not the same as a convention truck cab (I think they might be), contact Ray Stanley in millwright mass, he makes those things. He built door patch panels for my 41coe. Pm me for contact info. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
