| | | Forums66 Topics128,092 Posts1,056,461 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | My Chevy speedometer is giving me problems and have one for a GMC. Does the GMC speedometer have the same gearing so my MPH will still be the same? I know the cable connection is a bit different.
Thanks, Dennis
40 Chevy 1/2 ton
| | | | | Joined: Oct 2012 Posts: 182 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 182 | I believe the Chevy speedometer range is 0-100 mph and the GMC 0-80. | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I knew that! But, my pea-brain didn't register the effect. Looks like that is what is making the difference. Thanks so much for jogging the brain.
Thanks, Dennis
40 Chevy 1/2 ton
