6 members (SmalltownTRKGuy, Otto Skorzeny, moparguy, Gdads51, dt235sd, 1 invisible), 76 guests, and 4 robots.
Topics128,094
Posts1,056,056
Members48,433
What fluid and additive is recommended for a SM 420 transmission
dougs - the Shop Manual calls for the lubricants shown in the below extract from the 1948-51 Chevy Truck Shop Manual are what is specified for the SM420 4 speed transmission. No additives are called for. Here is an older thread on SM420 gear oil that provides some added info. Hope this is helpful. wink
~ Dan
1951 Chevy 3 window 3100
AD Addict & Tinkerer
90 weight straight mineral oil. No additives. You can buy it at Tractor Supply.
Transmission: 90w mineral oil https://www.tractorsupply.com/tsc/product/traveller-ford-tractor-hydraulic-oil-2-gal-t806600
Phil
Project Journals
Stovebolt Gallery Forum
Definitely DO NOT use the super-slippery synthetic transmission/rear end lubes. The inertia of those big, heavy gears will cause grinding because the synchronizers can't get a grip and match the gear speeds during a shift.
7
7 Offline
I filled my SM420 with Valvoline manual trans lube for synchromesh trannys, have had zero issues.
NAPA SAE 90W mineral gear oil or Tractor Supply's Traveller Tractor Mineral gear oil ISO 90.
Craig
O Online: Content
Tractor Supply. It's half the price of the NAPA version.
1950 Chevrolet 3100 (Ol' Roy)
1 Offline
Just an FYI as I posted in another thread last evening, I overhauled an SM420 about 2 years ago with a Novak kit. At the same time I switched from GL4 90 lube to mineral 90 from NAPA. I don't recall if it was their house brand. Anyhow, after about15,000 miles, when hot (steady running for a couple of hours) the 3rd and 4th gear synchros are grinding if I shift too fast. This never happened before. I don't know if it's the Novak synchros or the mineral oil but next time I change the gearbox oil I'll go back to GL4 90 if I can still get it.
1951 3800 1-ton
In the DITY Gallery
I too have been using the Tractor Supply gear lube and have had satisfactory results with it in two separate three speed transmissions.
I invest my money in precious metals, mostly rust!
