5 members (TUTS 59, Fannin, Phak1, Wheelie, chevyb), 284 guests, and 1 robot.
Topics128,084
Posts1,056,085
Members48,434
Hi all
I have a 216 stove bolt engine in a 1952 style side utility in Australia.
When I bought it it had an electric fuel pump fitted before the eom mechanical fuel pump.
It also had a Pressure Regular valve on the suction side of the electric pump.
Ie, pressure regular valve, elect pump, Oem mechanical fuel pump.
It all worked ok then it started to surge when you put the foot down and on occasion stopped.
I have removed the pressure regulation valve and the electric pump and left it as original with just the mechanical fuel pump.
Starts, idles fine and runs up to around 35mph then starts the jerking / surging thing like it’s starving for fuel. Gets worse as it warms up.
Been told to completely remove/ strip/ clean the carby. Also been told to replace the condenser first.
Appreciate any advice before I move forward.
Cheers
Max
7
7 Offline
Surging is typically associated with too little fuel, I would confirm the ignition system is 100%, then work on the fuel system. Make sure the fuel lines are clear and tight and not sucking air into the system, check pressure AND volume of the pump, then work on the carburetor.
Max - just a note that this topic best falls into the Engine Shop forum, so your conversation has been moved there. wink More replies and conversation coming! thumbs_up
~ Dan
1951 Chevy 3 window 3100
Most likely fuel pump volume and pressure if its running fine till 35mph
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
I'd GUESS insufficient fuel pressure too. But instead of guessing, I'd do as Jerry says and actually measure it. This will require a pressure gauge. A combination vacuum and fuel pressure gauge is your best bet and can be had for under $20 at Harbor Freight and may be available for loan out at your FLAPS. You may need a longer hose to reach into the cab so you can measure while it is failing. Check your Chevy Maintenance Manual for proper readings.
Thats probably why the electric was installed. If it was fine, check the screen on the carb at fuel line.
Check volume with the fuel line off at carb with a cup.
~ BD.
Riding in the Passing Lane
Check the fuel lines. Often someone has installed an extra fuel filter in the line that could be plugged up. That model is equipped with a shutoff valve under the tank. It has been known to get plugged up.
If the fuel system is ok take a look at the ign. points. the spring can be weak or sticking in the pivot.
George
1972 Chevy c10 Cheyenne Super
