| | | Forums66 Topics128,023 Posts1,055,366 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 39 Member | | Member Joined: Feb 2001 Posts: 39 | hello all. what is the best type of electric sander to use to smooth out the old paint so i can paint over it? or does it take ol fashioned hand sanding to do it smoothly? thanks!
1948 GMC 250 Series Flatbed
| | | | | Joined: Aug 2001 Posts: 35 Member | | Member Joined: Aug 2001 Posts: 35 | It depends on what you're sanding. I use a 1/4 sheet palm sander (electric) to do much of my sanding. It takes time and multiple grits of sandpaper but works.
However, I don't know the correct answer. | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | There is no "correct" answer, but I do have questions about what you are doing and why. Painting involves a lot of hard work. To get a good paint job, the old paint must have good adhesion to the metal, no rust underneath, and it must be stable (not breaking down especially to UV rays). Unless the paint is in good condition and there is no rust beneath it (not likely on old trucks) I would recommend removing the paint completely, either by chemical (stripping) or mechanical (sanding, blasting) methods. Add to that a coat of good primer (I prefer an epoxy) and you will be on your way to a long future with your new paint job. Now if you are trying to sell the vehicle, it's an entirely different story. As for sanding, many use an orbital sander first going from a medium to a fine paper. In-line sanders are a great help, too, but sanding with rubber backing blocks by hand is tough to beat, especially for the final smoothing. You might want to post this question in the paint & body forum, there are some there who are far more knowledgable than I.
Fred 52 3600 69 C-10
| | | | | Joined: Jul 2001 Posts: 149 Member | | Member Joined: Jul 2001 Posts: 149 | Dewalt palm sander is one of my best tools in my arsanal! I have sanded cars, body filler I even used it to finish dry wall mud! I have striped furniture and wood doors in the house stained them then polyurathaned them. Used it there too! I have dropped it kicked it sometimes at the sametime. hasnt missed a lick! And it was only bout 50 bucks Dan
"Finish the thing, do it right the first time, and drive the S.O.B.!"
1949 Chevy half ton 3100 In a kazillion pieces 2000 GMC Serria 1500 SL 4x4
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | If your priming orbital or palm sander are okay, but under finish coats I'd agree with Fred T that block sanding gives smoothest finish. Block sanding lets you see highs and lows in paint. Also helps to mist a contrasting color over primer when you sand, high spots come off first low spots show up.  | | | | | Joined: Feb 2001 Posts: 39 Member | | Member Joined: Feb 2001 Posts: 39 | i don't know! the old paint seems really tough. i was thinking of fixing the holes and getting rid of the surface rust, but not removing more "solid" paint than i have to. by no means will this be a show truck with an expensive paint job, but i do want it to look good. i have a dewalt palm sander but it really does take a while on some things. i also use a drill and sanding disks. i guess i was wondering how the orbital sanders worked cause i never used one. thanks everybody!
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Air powered orbital sanders work faster than there electric cousins do. I have an electric 6" orbital sander, sands nice but not as fast. The only thing with a DA (orbital sander) is it require a decent size compressor, most DA need 8-11 cfm at 80 to 90 psi.  | | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | I have never liked using electric or air powered sanders for preparing a vehicle for a paint job. Nothing beats wet sanding by hand for a smooth finish. It is a lot of hard work, but the results are worth it.
[ 01-12-2002: Message edited by: bigbassmann ] | | | | | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | Based on my body and paint man's advice, I bought a Dual Action orbit air sander from Harbor Frieght for $20. He says to use 80 grit to knock the old paint off, then go with finer grits. Hey, I'll try it, can't go wrong for the price. | | |
