6 members (Jon G, klhansen, dt235sd, Tim Canfield, Oswald, 1 invisible), 92 guests, and 2 robots.
Topics128,035
Posts1,055,445
Members48,422
#156719 01/31/2004 9:39 PM
Junior Member
Junior Member
What kind of tool is used to remove the screws with hourglass shaped slots that seem to be scattered through the cab interior, firewall, and larger ones on doors?
Wes
#156720 01/31/2004 9:43 PM
Junior Member
Junior Member
Duh,
Reading is fundamental. I found the answer to my question by just reading a couple of earlier posts. I'll bother y'all with a real question some other time.
Wes
#156721 02/03/2004 5:18 PM
Wes, as you discovered, there's a lot of good info in the tech section on this site. Clutch head screwdrives are available, there's a tool store locally that sells Channelock brand. Also, you can get them to fit 1/4" drivers, which lets you put them on a ratchet. If I had it to do over again, I would buy just the bits and forget the handled screwdrivers.
Fred
52 3600
69 C-10
#156722 02/04/2004 3:01 AM
I have never managed to find a bit for the largest clutch-head screws. However, some auto parts stores, such as NAPA, usually have the handled drivers. They are rather obsolete, but the tools are available.
1954 GMC De Luxe COE
#156723 02/04/2004 3:50 AM
NAPA does sell the largest size, but it may make sense to get a full set for drivers. If you're just getting started, you're going to put some miles on each of them!
#156724 02/04/2004 4:50 AM
Do any screws on our trucks use the smallest clutch-head size? I have two sets of three bits (the largest isn't included in either), and the smallest never gets used. My family has 4 various AD trucks around, and I have never used the little clutch-head bit, only the three larger sizes.
#156725 02/08/2004 8:24 PM
I bought a set of clutchhead screwdrivers fron Chevy Duty for around $15.Golden State,and Brothers also sell them for about the same money.
#156726 02/08/2004 10:57 PM
GMC Panel-
I understand that small clutch head screwdrivers can also work for some carb adjustments, Holley I think.
Moderated by  MNSmith
