6 members (JW51, KEVINSKI, Joe H, WingWright, 3800GUY, Gdads51), 121 guests, and 1 robot.
Topics128,110
Posts1,056,255
Members48,437
Can anyone help I’d my VA please.
It has 9 stamped above the outlet port.
143 stamped on the clamp and 568? Stamped on the actuating arm.
My fitted VA seems to be faulty (distributed not rotating when engine revved).
This came off a parts distributor and after a lot of gunk cleaning looks ok, actuator arm moves slightly when sucked on.
Will this suit on a 235 55Z numbered standard engine?
I’ve ordered a NOS one off eBay but 3-4 weeks is normal delivery time, so I thought I’d use this one in the meantime if it works.
Any help with what the numbers actually mean and what vehicle it’s for would be appreciated.
Cheers
Danny
1955 2nd Series 1/2-ton
"Bolting in New Zealand"
Follow this story in the DITY
Why worry - - - -just drive it until the new one comes in. The only problem a non-working vacuum advance will cause is the loss of a couple of miles per gallon gas mileage.
1 Offline
An NOS one will have a removable cap with a spring under it so you can experiment all you want shimming the spring to advance or delay the vacuum advance. I have never mucked around with that but there are specs and I think the trucks were different than the cars. Advance was supposed to start at 4 in hg IIRC.
The fifties GMC medium and heavy trucks I worked on didn't have a vacuum advance at all. Think of a GMC dump truck grossing 32,000 powered by a 270. The throttle only had two useful positions; wide open or idle.
1951 3800 1-ton
In the DITY Gallery
Thanks for that. Like your truck and the story that goes with it.
Have a great 2025😀😀😀😀😀
