9 members (Gray_Ghost, cmayna, treegrower, Barney1951, UtahYork, Rusty Rod, TUTS 59, Rusty Heaps, 49choptop), 102 guests, and 1 robot.
Topics128,067
Posts1,055,877
Members48,428
#1566722 12/29/2024 2:46 AM
I’m wiring up with a new harness and I’m having trouble getting the horn to honk. It’s a 12V system and the horn works when hooked up straight to a battery but not to the wiring harness
The lead on the harness to the horn is continuous positive.
From the relay(3 prong) one wire supplies power.
Second prong from relay has no power
Black wire from last prong is constant power and says to connect to horn on column.
Is this correct? I thought the column was negative. Also horn has a continuous positive?
Daniel
1949 Chevrolet 3600
second2nun #1566723 12/29/2024 2:51 AM
The horn button grounds against the wheel/column when pushed, completing the circuit.
Make sure the parts under the button aren't painted or rusty and make good contact. The hole in the wheel is where a little spring loaded button sits that keeps the horn button from grounding until it's pressed.
1950 Chevrolet 3100 (Ol' Roy)
second2nun #1566725 12/29/2024 2:55 AM
Your relay should have a +12V input from the battery, an output to the horn, and a "switch" that goes to the horn button.
When you ground the "switch", it should connect the +12V input and the horn output.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Yes. Thank you I do have it cleaned up.
Daniel
1949 Chevrolet 3600
Fibonachu #1566732 12/29/2024 4:02 AM
The relay shouldn’t have a constant +12V to the column(horn switch) right?
On a three prong relay it’s a supply 12v, a negative (switch to horn button ), and the lead to the horn right?
Daniel
1949 Chevrolet 3600
second2nun #1566735 12/29/2024 4:39 AM
The "negative (switch to horn)" should show battery voltage UNTIL the horn button is mashed. Then it should show zero volts and the horn should be making noise.
second2nun #1566813 12/30/2024 3:22 AM
Thanks everyone! Horn works. Loud and a bit funny sounding. Might need to look for a horn with a lower pitch.
Daniel
1949 Chevrolet 3600
second2nun #1566818 12/30/2024 3:46 AM
Uncertain about the pitch preference wanted. But, pitch can be adjusted or tweaked. My recollection is a bit foggy on the process. A search here in the Bolt is where I found that info?
second2nun #1566866 12/30/2024 8:26 PM
What do you mean by "funny sounding"? They definitely don't sound like most horns from the 60s and 70s or even those of 50s Cadillacs, etc.
They sound like VW Beetle horns. That's normal if this is the horn you have.
second2nun #1567020 01/01/2025 2:39 AM
I tightened the nut inside and it now has a great tone. Was just loose. And yes very 50s and appropriate.
Just a bit more wiring. So close.
Thanks everyone!
Daniel
1949 Chevrolet 3600
