1 members (baldeagle), 87 guests, and 3 robots.
Topics128,037
Posts1,055,467
Members48,424
#1566423 12/25/2024 12:01 AM
I recently swapped my 1950 216 engine to a 1953 235 but the 235 has a cracked head. Will the head off the 216 work on the 235?
1950 4400
Joe Alan #1566425 12/25/2024 12:27 AM
Nope- - - -not enough head bolts on the 216 head. The early spray-oiler 235 (at least some of them) used a head that would interchange with the 216, but the last of those engines was made around 1951 or 52, I believe. Some of the 53 216s ran the same head as the 54/55 235, but I'm by no means an authority on what casting numbers work on which engines. The head that everybody wants has "848" as the last three digits of the casting number. It was used from about 1956 to 63, and has a higher compression ratio than the earlier 235 heads (54-55).
If that 216 is looking for a home, send me a private message. I modify them to get 250-something cubic inches, with a full pressure 235 crankshaft and different pistons.
Joe Alan #1566430 12/25/2024 1:04 AM
What Jerry said.
Here's a comparison of the two. Note that there's no bolt on the 216 in Position 1 shown on the 235 diagram. The others might match up, but likely not.
Also a part listing of 6-cylinder heads from the 1929-1957 Chevy Parts book.
Joe Alan #1566434 12/25/2024 1:25 AM
Yeah I see what you mean, thanks for the replies guys.
1950 4400
