3 members (Otto Skorzeny, baldeagle, 52Carl), 84 guests, and 2 robots.
Topics128,130
Posts1,056,714
Members48,454
Hi
I had a look at AK Chevrolet truck for sale here in Denmark today, but I am bit puzzled by the chassis number as it does not match any format I have been able to find.
Am I missing something ?
1941 CMP Chevrolet
12 cab gun tractor
Great exchange in Big Bolts
1946 Chevrolet 5400 COE
132.5" WB
Details in Big Bolts
1944 Scammell Pioneer x 2
Held on by pop rivets?
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
On the chassis number, I believe the X is an add-on at some point. 8PW would be the plant (8=Atlanta) and model (PW=6400) for a 1946 truck. The following numbers would be the 2772nd truck off the line.
The DEA prefix on the engine number also indicates a 1946 Flint plant built engine.
So rather than a 1947, that appears to be a 1946 data plate. If you can find the serial numbers on the rear axle and transmission, that will help determine the actual truck year. As Kevinski said, a data plate pop riveted on is suspect. See attached for reference.
Nice looking truck, though.
I'm not a '46/47 expert, but did the firewall data plates for USA trucks have a line for engine numbers?
My thought is this is an export truck and the "X" is for Export and the data plate with the engine number got added to those units...just a guess.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I think Mike B's idea has merit on the "X" being used to identify an exported vehicle. Not specifically related to a truck exported to Europe, but this very old conversation in the VCCA forums alludes to the "X" being used at the beginning of serial numbers on Canadian manufactured Chevrolet trucks exported to Australia. Could be that's how GM did it for all exported vehicles when post WWII production resumed???
This might be a question to post in the International Zone forum where others Bolters in Europe can offer any related answers or info. headscratch
~ Dan
1951 Chevy 3 window 3100
Hi
Thanks for all the comments.
I was also pondering if the X could be something about denoting export or if it could be a locally assembled one.
There was Chevrolet Assembly factory in Copenhagen from 1923 until 1965.
The truck had been restored at some point, and the data plate has most likely been off to allow for painting, and then pop rivet back.
Here in Denmark its only stamped chassis numbers in frame or body work that are valid.
It was fitted with a 1954 engine, overall it had been an okay truck, but it had suffered from standing outside for a while and needed redoing now, so I walked away.
1941 CMP Chevrolet
12 cab gun tractor
132.5" WB
O Online: Content
That's too bad. Lot rot doesn't take long to set in on vehicles left outside and not driven.
1950 Chevrolet 3100 (Ol' Roy)
Yes, in the climate we have here you cant store anything outside, without heavy deterioration.
Even though it was sad to see it in this condition, it was also good as I could walk away from it without buying it because I am not looking for any more projects.
1941 CMP Chevrolet
12 cab gun tractor
132.5" WB
