1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2001 Posts: 35 Member | | Member Joined: Aug 2001 Posts: 35 | I got my new compressor (I've been talking about it and asking questions for several weeks...).
I have a couple questions about wiring it - no plug, needs to be wired. I was figuring on wiring on a heavy duty plug and wiring an outlet for 220 rather than direct wiring the compressor - hows that sound?
The motor says 15A - will a 30A breaker be enough to handle the start up spike? Don't want to blow the breaker each time and don't want to dim the house lights. | | | | | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Yes cord connected for a compressor like yours is legal.If the motor data plate says 15 amps FLA (full load amps), then a 20 amp breaker will be adequate. The breaker should be labeled HACR, meaning its motor rated.The wiring apacity rating should be 125% of the motor amps.#12 wire is close enough. Buy the proper receptacle and male cord cap rated for 20 amps at 240 volt, 2 prong plus a ground.As Ken mentioned before ,home compressors have built in overload protection so your good to go.Have fun. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Tony or Ken could you maybe post something on how to make a phase converter out of a electric motor(wiring,HP and stuff).Did it with and old timer many years ago,but he just passed away (at the age of 93 he was still workin) and i have no one to teach me all the wonderful stuff he had taught me.  I have a small box style one to run my bridgeport but am buying a bigger 3 phase lathe and the motor to change it over would be real expensive.I only need about half power for it so the converter would work ok.(no weldor stuff) Thanks Bruce | | | | | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Old phase convertors were mechanical devices.I haven't seen one in years. Today you can buy a small solid state converter for a few hundred bucks.. I think they make models up to 5 HP.They work fine for motor like a mill that doesn't start with a load on it.Phase converters don't supply true 3 phase power but a modified single phase power. This is not something I'm real familar with as I do mostly power distribution work.Most wireman look at phase converters like putting a 4 bbl carb on single barrel adapter.I Have installed the new solid state ones a few times for friends. They were satisified with the operation. | | | | | Joined: Nov 2001 Posts: 72 Member | | Member Joined: Nov 2001 Posts: 72 | Phat, Check your e-mail. I just sent you some 3 phase diagrams. Dennis | | |
