0 members (), 146 guests, and 2 robots.
Topics128,162
Posts1,056,939
Members48,458
Where do you put the Voltage Reducer on 49 ? Do you mount it on the back of the Gauge or can you put it on the Sending unit? If you have to put it on the Gauge which post does it go on or does it matter?
TIA
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
Voltage regulator goes between 12v supply and the terminal closest to the "E" end of the gauge. The sending unit wire connects to the terminal closest to the "F" end of the gauge.
