| | | Forums66 Topics128,043 Posts1,055,612 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 33 Member | | Member Joined: Nov 2002 Posts: 33 | does anyone know where i could find a "good" set of these drivers. i found some cheap one but they just strip, not the screw but the tool. any help would be greatly appreciated? thanks | | | | | Joined: Feb 2000 Posts: 90 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 90 | The first thing I ordered from Chevy Duty were Clutch Head Screw Drivers. They are well made and work very well although I ended up surgically removing 90% of those clutch head bolts with a thin wheel on a small angle grinder. Good Luck
Terry 1953 1/2 Chevy | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | reddspeed2002,
Chev's of the 40's use to have a set of tips with a 1/4" drive socket. The tips were good, hard metal. I agree with Terry - Chevy Duty has a good set of drivers AND many of the screws break off, even with good drivers (and plently of penetrating oil).
Tim | | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 |
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | I have had the best luck with Snap-On. They seem to be the toughest and the warranty cannot be beat. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | I see " clutch head drivers " all over the road every day. They are usually going the wrong way on a one way street or drive for a mile with their left turn blinker on & make a right turn at the last minute. :mad: Napa has the clutch head tools on the shelf. | | |
