4 members (klhansen, 37 GC, Hotrod Lincoln, Philipj), 92 guests, and 1 robot.
Topics128,143
Posts1,056,786
Members48,454
Crusing in the Passing Lane
If adding a right side rear view mirror where GM did not provide mounting hardware(my ‘55), it is easy to make a nut plate with machine screws rather than using sheet metal screws, even though the tin is two layers thick in places. This will provide a secure mount that may be used several times without distorting the mounting surface. Make sure to get a buddy to properly locate the mirror fore and aft, will not necessarily line up with the driver’s mirror.
Ed
Ed, on my '51, there were holes in the reinforcement under the cowl. I just used those to locate the holes in the cowl. The repop right side mirror bracket has just two holes like the original left side bracket, but the bends in it locate the mirror head forward so it's visible through the windshield instead of the side window.
Hard to tell, but your truck may be a Task Force 55.2 series. The nut plate is a good idea. thumbs_up
Kevin, yes mine is a ‘55.2, three mounting holes on the driver side, both sides match.
Ed
