Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
5 members (moparguy, Otto Skorzeny, Wally / Montana, mick53, Flatlander), 575 guests, and 1 robot.
Topics126,776
Posts1,039,259
Members48,100
Most Online2,175
Jul 21st, 2025
#1564167 11/26/2024 12:07 AM
U
U Offline
Can someone tell me what is a SM420 transmission? I have a 4-speed manual. Is that a SM420?
~ John in Utah
Here We Go
Follow in his DITY Bay
Busta1 #1564179 11/26/2024 2:53 AM
If it came in your '55 2nd series and your truck is 2 ton or less it is an SM420.
Busta1 #1564182 11/26/2024 3:18 AM
U
U Offline
OK - Should have been more specific. I have a 1946 1/2Ton with 4-speed. Just new and I've seen SM420 a few times and wondered what my transmission was.
~ John in Utah
Here We Go
UtahYork #1564197 11/26/2024 2:47 PM
Sorry John. I don't know why I thought you had a 55.2 truck.
GM started using the SM420 transmission in 1948, so if original your '46 would not have a SM420. I don't know what they called the earlier 4 speed.
The prior-to-1948 four speed transmissions did not have synchronizers on 2nd, 3rd and 4th gears like the SM420 did. You'll have to learn to double-clutch.
UtahYork #1564200 11/26/2024 3:08 PM
John, The earlier 4 speeds (before SM420) are known as "crash box" transmissions. None of the gears are synchronzed, with straight cut gears that you will need to learn how to "double-clutch" to shift smoothly. The pic below is a screen grab from a 1941 Chevy Truck dealer handout. Your 4 speed is shown on the right (1946 is basically same design as 1941). Lots of posts on this type of transmission as well as some helpful hints on "double-clutching". Here is a great earlier thread on "double-clutching" that may prove useful. smile
~ Dan
1951 Chevy 3 window 3100
UtahYork #1564207 11/26/2024 3:37 PM
U
U Offline
Is it just preference if I should keep my original "crash box" transmission or upgrade to a later transmission with synchros? If upgrading, are there any direct bolt in transmissions that work with my 1946 torque tube? Sorry for all the questions. My truck is currently dissembled and just trying to figure out options.
~ John in Utah
Here We Go
UtahYork #1564208 11/26/2024 3:40 PM
Just read the earlier thread that Dan provided above. Wow! What a challenge it would be for me to learn to operate a crash box. Think I'll stay with my SM420
Craig
UtahYork #1564210 11/26/2024 3:50 PM
W Online: Content
I found I needed to double clutch the 4-speed in my '48. (Worn synchro gears?) My left knee started to suffer with the extra clutching. So, during a shift, I just pause in the neutral position for an instant before putting it in the next gear. That got rid of any grinding. I don't know why this works for my '48 but I'm happy.
33 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
UtahYork #1564212 11/26/2024 4:01 PM
John, one option is to find a 3 speed transmission from the same era. That is almost a direct bolt in requiring only the proper pedal bracket or one can add shims to the bracket (stack of washers) to account for the fact the 3 speed tranny is narrower. The 3 speed transmission will be synchronized from 2nd to 3rd. These transmissions were the standard for the 1/2 ton trucks of that era so there is a good chance you will find one.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
cmayna #1564213 11/26/2024 4:57 PM
U
U Offline
Yes. What a challenge on these crash box transmissions. Now that's driving!
~ John in Utah
Here We Go
UtahYork #1564218 11/26/2024 6:28 PM
I drove a Model A Ford with a 3-speed straight cut non-synchronized transmission for years. Like Wally said, slow and easy on the shifts was the trick, letting the engine slow down before engaging the higher gear on upshifting, or revving the engine a touch while in neutral on downshifts made for a clash free shift. It's even possible to shift without the clutch with enough practice (called float shifting). Matching the gear speed with the engine speed is the trick there.
UtahYork #1564244 11/27/2024 12:20 AM
O Online: Content
I drove a 1934 Brewster, which is essentially a Ford with luxury coachwork. It had a non-syncro transmission but it was one of the smoothest manual transmissions I've ever driven.
You could just east the shifter into position (no jamming it in or forcing it) with a little pressure and the gear would drop right in. I was amazed.
1950 Chevrolet 3100 (Ol' Roy)
1939 Packard Standard Eight Coupe (The Phantom) | 1956 Cadillac Coupe de Ville (The Bismarck) | 1956 Cadillac Sixty Special Fleetwood (The Godfather) | 1966 Oldsmobile Toronado (The Purple Knif) | 1966 Ford Mustang (Little Red) | 1964 Ford Galaxie 500 coupe | 1979 Ford F-100 | 1976 Ford F-150 (Big Red) | 1995 Ford F-150 (Newt)
UtahYork #1564308 11/28/2024 3:45 AM
1 Offline
I attempted to put a four-speed crash box from a 46 or earlier truck into a 48 that came with a three speed. The crash box was too short and I'd have to have moved the rear axle forward. So I gave up. The junkie wouldn't take it back so I had and extra useless transmission for years.
1951 3800 1-ton
In the DITY Gallery
UtahYork #1564322 11/28/2024 2:51 PM
U
U Offline
I still have my stock '46 4-speed which I'm planning to use again. I also have a couple other transmissions in my shed, but not sure what they are. I believe one is a manual from an early '50s truck and the other looks to be an automatic. As my project gets further along I'll try to post some pictures to see if anyone can identify them.
~ John in Utah
Here We Go
If your using the wrong gear lube you will grind the gears...you need to be using Mineral Oil, it's not as slippery as the modern oils.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1956 8400 Wrecker w/Holmes 525
1956 9200 Tractor w/Allison Automatic
1952 Willys M38 Army Jeep
1953 Willys M38A1 Fire Jeep
1978 Jeep CJ-5 Navy Jeep
1984 Jeep CJ7
Hughesville, MD
UtahYork #1564519 12/01/2024 1:37 AM
U
U Offline
Mineral Oil? What? Is that what the manual calls for? I was thinking 85-90w or I've heard some say the same as the differential?
~ John in Utah
Here We Go
UtahYork #1564520 12/01/2024 1:41 AM
O Online: Content
Tractor Supply sells the correct oil for these antique transmissions under the name Traveller ISO 90 Ford Tractor Transmission Fluid Mineral Oil.
https://www.tractorsupply.com/tsc/product/traveller-ford-tractor-hydraulic-oil-2-gal-t806600
UtahYork #1564527 12/01/2024 2:16 AM
O Online: Content
To answer your question, the 1948-1952 Chev. Truck Shop Manual states in General Lubrication, section 0-5 that;
Transmissions - S.A.E. 90 Straight Mineral Oil gear lubricant.
S.A.E. 90 "Multi-Purpose" gear lubricant.
Rear Axles - S.A.E. 90 "Multi-Purpose" gear lubricant.
UtahYork #1564536 12/01/2024 3:33 AM
Transmission lube does call for either Straight Mineral Oil or "Multi-Purpose" gear lubricant, but I don't believe "Multi-Purpose" lube contained sulfur compounds back in the 50's. It was probably rated API GL-4 which doesn't have sulfur compounds in it and is OK for transmissions with brass components. "Multi-Purpose" nowadays is generally API GL-5 which should NOT be used in our transmissions. It's also too slippery for the synchronizers to work correctly. API GL-5 was introduced in the 1960's. It's hard to find a M-P gear lube that's GL-4 or lower.
UtahYork #1564539 12/01/2024 4:42 AM
U
U Offline
OK - I'm learning new stuff all the time! I had my 4-speed transmission serviced/rebuilt and it is dry right now. I'll make sure to fill it with the correct oil.
~ John in Utah
Here We Go
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.064s Queries: 15 (0.058s) Memory: 0.6953 MB (Peak: 0.8387 MB) Data Comp: Zlib Server Time: 2025-09-22 01:36:18 UTC
Valid HTML 5 and Valid CSS
