8 members (TUTS 59, J Lucas, Bill Hanlon, GMCJammer51, NJC, Wayne67vert, 2 invisible), 76 guests, and 2 robots.
Topics128,263
Posts1,058,136
Members48,482
#1562979 11/11/2024 4:22 AM
Son has a '81 GMC 3/4 ton. Had a very tired 305 in it, with SM420 trans.
Just recently wrecked his '07 NBS GMC 3/4 ton with a 6.0L, 4L80E
We have full harness, computers, everything.
Anybody done this type of swap? Anything we should be prepared for?
1952 Chevrolet 1700 Bickle Seagrave
"Old Smokey'"
Following the build in the DITY Gallery
Yes I have dropped a 2013 6.0 / 6l90 in a 1956 3100
The swap is really straight forward if you have all the harnesses and computers.
And the nice thing is you even have the body control module so even more restomod options are available.
I would buy the tuner software so you can easily program the ECM as needed. (I used HP tuners but there are plenty of guys using others EFI live et)
Mountains of information on LS swaps on the internet. Videos, forums etc Bet you can even find one on the 81 getting a LS put in.
Only note of issues that I had to chase down. MY ECM required I delete the starter check along with the VATS and normal stuff. Took a while to find that one.
Soon as I got that set it fired right up.
Mounting should be straight forward.
Thanks hcb3200. Hopefully we'll be getting to it in the next couple months.
"Old Smokey'"
Moderated by  Leo
