4 members (Shardean, Tstan7, 2 invisible),
94
Mod | | | Forums66 Topics128,022 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 39 Member | | Member Joined: Feb 2001 Posts: 39 | i would like to do spot welding like the factory, and i recall seeing a special welding tip or gun (something like that) you can buy that claims to do this. does anyone know what im refering to and does it really work? thanks.
1948 GMC 250 Series Flatbed
| | | | | Joined: Jul 2001 Posts: 149 Member | | Member Joined: Jul 2001 Posts: 149 | Eastwood and Harbor Freight has one that looks like a big clamp. The Two "tongs" clamp together with what you want two weld together between them. An electrical current runs thru the "tongs" and create the weld. Their expensive. Can also drill a small hole in one piece of the metal then weld thru that hole onto the other piece to be welded to create a spot weld. I did this method this weekend works great. Later
"Finish the thing, do it right the first time, and drive the S.O.B.!"
1949 Chevy half ton 3100 In a kazillion pieces 2000 GMC Serria 1500 SL 4x4
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Are you talking about the one that Eastwood or JC Whitney have. You use it with your welder. They cost about 39.95 or so. I bought one of those, didn't really impress me to well. All the rods are, are shortened welding rods that fit into gun. You hold trigger to weld.  | | |
