3 members (TexasA&M48Truck, Peggy M, 1 invisible), 118 guests, and 3 robots.
Topics128,081
Posts1,055,955
Members48,430
#15618 12/17/2001 2:34 AM
Hi, Just having a bit of a proble making the valve cover leak proof. Any tips would be welcome. It appears to be staight and flat but the darn thing leaks like a you know what! I have tried two types of sealers and new gaskets to no avail. HELP, DAVE
1940 GMC 1ton, red/black flatbed stakeside
1998 Dodge 3/4 ton cummins pumped and lifted
1940 GMC 1ton flatbed red with black fenders original great condition.
1998 Dodge 2500 quadcab short bed cummins,pumped and fast
#15619 12/17/2001 3:00 AM
What kind of engine are you working on
kdot em3
#15620 12/17/2001 3:11 AM
sorry about that, its the stock 228
#15621 12/17/2001 1:06 PM
First check the flatness with a straight edge that is long enough to cover most all of the surface where the gasket sits. If over all flatness is ok. Make sure you aren't over tightening the bolts/screws that hold the cover down. If I remember right, all you need is about 5 to 7 foot pounds. As soon as you see the gasket start to squeeze out stop. It helps to put your sealant on both the cover and the head.
If at first you don't succeed, get a bigger hammer.
1941 Pontiac business coupe
1947 Chev Coupe
1969 GTO ragtop
#15622 12/17/2001 3:27 PM
DaveD
I have a couple of questions:
Has this motor been recently overhauled?
(if so I am stumped follow previous advise)
If not:
Is there a lot of sludge on and around the valves and springs?
(you may have slow oil return - clean out oil return passages)
Good luck
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#15623 12/18/2001 2:13 AM
DaveD, I have the same engine in my GMC. That gasket can slide around because there are no bolt holes to hold it in place. Taking the advise of a few guys here, I used some 3M weatherstrip adhesive to stick the new gasket to the valve cover itself. Don't install the cover until the adhesive is dry, this way you can be sure that the gasket is stuck to the proper place under the cover. Those valve covers also have a cone shaped nut and rubber washer to fasten the cover. If you are not using the proper nuts and washers then oil could leak out the two holes as well.
[ 12-17-2001: Message edited by: 53 4 me ]
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#15624 12/18/2001 4:27 AM
Thanks for the tips. Using the weatherstrip adhesive sounds alike a great idea. I have checked the valve cover for flatness and it is really pretty good. I was real careful the last time to not tighten it to much in fact I was afraid it might come lose but it still leaks. I am giong to try the weatherstrip stuff I will let you know, Dave
#15625 12/18/2001 4:40 AM
3M's the way to go...... NEVER USE SILICONE! Jeez, I hate that stuff on cars! (I'm a mechanic). Silicone fills gaps, but doesn't adhere to metal well, so it leaks. The previous posts are right on! wink
John Kennedy
1950 Suburban street rod
Pics in the Gallery.......
new site up!
http://home.joimail.com/~kennedyjp/
#15626 12/19/2001 5:58 AM
Dave, for what it's worth, I had a similar problem with a new-used oil pan on my '44 235. Put it on, it leaked. Put sealant all around it, it still leaked terribly. Eventually sent it to a "mechanic". He put it on, and it leaked. He said he finally learned from someone to "pop" the pan, to get it to the right shape. I'm not sure what that means, but it sounds sorta like a twisty, back-cracking sorta allignment thing. Anyway, what-ever it was, it did the trick!
Probably no help at all, but thought I'd throw it in! :confused:
-Michael
Please type slow, as I can't read very fast.
1939 Chevy/Central Fire Engine
1941 Chevy/American Fire Engine
1950 Chevy/American Fire Engine
More Photos in Me Gallery
#15627 12/19/2001 6:48 AM
Well, i have 3-m'ed the valve cover and gasket. It looked good stuck on real nice, then 3-m'ed the gasket-valve cover to the head. Its just sitten in the garage waiting till tommorrow. I thought I should let it set up overnite so I'll let you know what happened. I have found another valve cover though so i guess thats the next step if this doesnt work. dave smile
#15628 12/19/2001 10:45 PM
Dave, When I did my valve cover, I did not use adhesive to stick the valve cover gasket to the head. The adhesive holding the gasket to the cover is sufficient to hold the gasket from moving around.
Bill M
53 GMC Hydra-Matic
Home Page
#15629 12/20/2001 6:38 PM
Well it worked. I may have blown it though cause I stuck it to the head as well. Good thing I adjusted tyhe valves first! But it doesnt leak! and thats one leak down and 2 to go( pan and side cover). Thanks for the tip, Dave smile
