3 members (RLB, 1955 1 Series, Peggy M), 101 guests, and 1 robot.
Topics128,105
Posts1,056,542
Members48,448
I'm working on installing a mid 1960's Saginaw OD version transmission into my 1950 GMC. The reverse light switch does work, but the pigtail does not. Does anyone know of a source for this pigtail?
Thanks!
1950 GMC 100 Panel Truck, 1958 270,
3-spd Saginaw with BW OD,
3.73 12 Bolt Differential from a 1966 C10,
Front Disc Brakes
Hill Holder
Bought it in pieces 9-1976, driving since 6-1978
Follow in the DITY
I was not able to find that pigtail for my truck, so I ended up putting a pair of female spade connectors on the end and covering them right to the tips with heat shrink to seal them.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Robert: You could fit a scrap piece of plastic between the two female spade connectors that Fibonachu is recommending to keep the spacing of the connectors before shrinking the heat shrink.
Thank you both for your ideas. I will do both! I've not yet tried heat tape, so I can learn something new.
Front Disc Brakes
Hill Holder
Follow in the DITY
I've only tried heat shrink TAPE once and I wasn't happy with the results. I use tubing.
The only advantage I can think of for the tape is to put it over wiring that already has terminals, plugs, or other connections on both ends. I will admit that I have more than once set up wiring on both automotive and computer gear with plugs on both ends that were too large for the heat shrink tubing to slip over, only to find the piece of heat shrink tubing sitting on my workbench. Oh well, take one end off, slip the tubing over the wire, reinstall the end and then shrink the tubing.
I have also never had a good experience with heat shrink tape.
Tubing all the way.
Is the rubber cap really necessary? There are fully insulated spade connectors, both male and female, available at any good auto parts store. Maybe use a piece of shrink tube about an inch long just behind the connectors to keep the wires together.
Can you provide a pic of the end of the pigtail or switch terminals? Are the two terminals at a 90 degree angle from each other?
Craig
Thank you all for your advice. I agree with everyone who points out that I need only 2 spade connectors, but I look also to keep road splash out of the switch. Here is a photo of the pigtail. It measures 21/32 on the inside. If shrink tube will fit over the 21/32 switch OD and also shrink to the diameter of 2 wires, then that seems like what I should do.
Front Disc Brakes
Hill Holder
Follow in the DITY
Insomniac
Insomniac
I needed one of those. I picked up one off a wreck.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
I've have a back up switch connected to my SM420 for a few years now. Have 2 separate female spade terminals connected which has never encountered very much if any, road grime. Think you'd be just fine with your plan of attack.
Craig
Fixed! After consultation with Bill Hanlon I found that I had continuity from the plug tabs to the ends of the pigtail. I then sprayed inside the plug with contact cleaner and reinstalled it. It works now. The near 60 year plastic insulation is not interested in bending, so I believe I will try the heat tubes on each of those wire.
Thank you, Bill and all others who offered advice!
Front Disc Brakes
Hill Holder
Follow in the DITY
Glad you got it working Robert. Hope you picked up your GrandSon from day care on time. You don't want to get on those peoples' fecal roster.
A piece of heater hose and a tube of high temp RTV sealer will make a totally waterproof connector. Just slip a 1" long piece of hose over the connectors and fil it with RTV.
